Modular V10 (6.8l)
weired over heat issue, need help
Old Jun 22, 2015 | 06:19 PM
ironman1977's Avatar
ironman1977
my v10 when air is running every few months all of a sudden spike to hot and got to reduce power, i turn off air and in 2 minutes it goes to normal, i can start air back again and not have any more issues to a few months later it will do same thing again, it will not does gradual climb and fall it will spike all of a sudden, turn off air and it will go back to normal in 2 minutes, i need to know if anybody has a idea what is going on
Old Jun 22, 2015 | 09:44 PM
northwindone's Avatar
northwindone
I've seen the sudden spikes in temperature be caused by a bad CHT sender, which of course is a false reading, and also be caused by bubbles stuck in the coolant system after a flush. Both of these would cause the engine to go into "safe mode" shutting down 1/2 your cylinders. Not sure what would cause it with the A/C running, at least not that quickly.
ironman1977
Jun 30, 2015 11:58 AM
Murf_2002_F150
1997 - 2003 F150
31
Dec 16, 2013 09:31 AM
EagleKeeper1026
Mar 17, 2011 07:08 PM
CB'97EXPY
Nov 16, 2010 09:34 PM
Lock
Aug 3, 2009 05:48 PM
