Sponsored by: Real Truck
4x4 not working
Old Jun 8, 2006 | 02:08 PM
biz4two's Avatar
biz4two
Arrow
Originally Posted by Hotrod50
What about the hubs not coming OUT of 4 wheel drive? I get a clunking when I try to turn now, and I don't know what to do about the hubs staying locked in 4x4.
With the hubs in the 'Auto' position and the transfer case in 2wd. Try backing up about 15-20 ft at a steady quick pace. That might just unlock your 'Auto' hubs.
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Jun 8, 2006 | 03:19 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Others here have said turning the hub from AUTO to LOCK and back to AUTO gets them to unlock. I've done that, and sometimes it worked and sometimes it didn't (my hubs were failing).
Old Jun 8, 2006 | 03:31 PM
hickoryford's Avatar
hickoryford
You can also grab the knuckle inside each front tire and move it back and forth, alot of times that will force the hub loose. They are easy to service and if they are sticking, I would take them apart and put on a new fresh light coat of grease on them.
Old Jun 8, 2006 | 03:42 PM
krewat's Avatar
krewat
By the way, when mine went, they wouldn't stay engaged some of the time after the initial vacuum pulse, the internal toggle lock/unlock thingy was worn. Not to confuse anyone.
Old Jul 4, 2006 | 10:16 PM
desbrs's Avatar
desbrs
Did you find out the problem! I have a 2001 doing the exact same thing.
tellarae
Dec 29, 2012 10:33 PM
ncinirator
Jan 11, 2011 01:49 PM
wildmand
Oct 14, 2010 03:08 PM
broke-n
18
Apr 5, 2009 12:01 AM
index_case
Bronco II
Feb 13, 2004 02:11 PM
