OK boys. Here we go again. It's a 351M in a 79 F150. I've got a miss in cylinder six. It does have spark. Per your suggestions, I bought a compression tester and sure enough, number six registers a whopping zero. Number two is also low (60 lbs) but the rest look OK. (100 to 110 lbs.) I removed the valve cover and cannot see anything drastically wrong. i.e. no broken springs. Now what? I'm assuming that the exhaust valve is the issue here, but I don't know how to tell. I find it hard to believe that the rings are bad in one cylinder. Any ideas?
Back off the rockers on #6, and put air pressure into the cylinder. Look for air flow out of the exhaust (exhaust valve), intake manifold with carb open (intake valve), or crankcase (ring or piston).
I am betting on a cracked piston or broken ring, because even bad valves seal sometimes. Did you have any oil burning?
I recently took one apart and had 3 compression rings break when removing pistons- no real lip to speak of but had 80 or less in all 3. No pressure seems interesting to me...but most things i can't explain are.
So best case scenario is rebuild heads...most likely engine needs it...thats my luck...the luck of the unirish.
A cylinder can also have low to zero compression if the piston is damaged (usually accompanies cracked rings). If only one comporession ring is cracked on a piston, then it can still maintain a fair amount of compression. Now if the same scenario is taking place with a damaged piston (ring lands cracked through to the inside of a piston) then you will see a huge loss in compression.
[QUOTE=grclark351]a severely damaged or holed piston will be pretty obvious if you remove the oil fill cap while the engine is running, it'll be blowing air in and out.[/QUOTE
Yep, that's at least one thing tcbofade needs to check for.
OK, well I guess the good news is that it didn't look like a steam engine. lol. I've got a buddy with an air compressor and we'll chase the air flow...hopefully tonite. Otherwise I'll have to wait for the weekend. I realize that either way I end up pulling the head, but if I've got a bad piston and or ring, I want to know that I'm looking at a complete rebuild before I start.
