New engine wont crank!
Old May 28, 2006 | 06:27 PM
S.N.A.F.U's Avatar
S.N.A.F.U
So I just rebuilt my 302 and now it wont crank over,its like its locked up almost.When it was on the stand I could crank it over with a breaker bar.I made sure the truck was in neatural and it wont crank.At firdt the starter woul engage against the fly wheel but now Im pretty sure I screwed the teeth up on the starter and it just makes a horrible noise.Any ideas?
Old May 28, 2006 | 06:56 PM
Bdox's Avatar
Bdox
See if you can turn the engine by hand now that it is in the vehicle before you go any further. If you can, then inspect the starter/flywheel teeth to see if there is too much damage for it to work.
Take a close look at all the battery cables. There are four counting the engine to chassis ground, neg battery cable, pos battery cable and starter cable from the solenoid. Make sure that they are all in good condition and clean all the ends and the surfaces that they contact. Coat the ends with a light coating of grease and snug them down.
If that doesn't get it, post back.
Old May 28, 2006 | 07:13 PM
jade79's Avatar
jade79
Don't take this as an insult, (since I don't know you or how much experience you have) did you properly adjust the valves? If they aren't opening, that would create a situation like you are describing. Is there anything caught between the block and bellhousing causing the torque converter/trans to bind? If it's an automatic, is the torque converter seated in the trans pump all the way?
Old May 31, 2006 | 10:01 AM
Kemicalburns's Avatar
Kemicalburns
if the crank mains caps werent installed in the correct order or put in backwards then it will also cause this.
Old May 31, 2006 | 10:06 AM
sharpster68's Avatar
sharpster68
also if it is a auto matic make sure the flywheel is on the correct way. if its on back wards it will bind against the block and or spacer plate.
Old May 31, 2006 | 10:50 AM
Bdox's Avatar
Bdox
Which points out the value of giving complete vehicle information when asking a question.
Old Jun 1, 2006 | 11:22 AM
Tech-man's Avatar
Tech-man
If the main caps were incorrect it would not turn over on the stand.....
Old Jun 1, 2006 | 01:56 PM
Kemicalburns
good point i should have caught that
Old Jun 1, 2006 | 11:20 PM
S.N.A.F.U's Avatar
S.N.A.F.U
OK so I got side tracked and kinda forgot I posted this.Right after I posted it I droped the starter and noticed the starter gear was a little tweaked so I went to NAPA where I work(thank god I have 24 hour acces)and got a new starter threw it in and it turns over perfectley.Thanks for the replies,I hope to have it runnin this weekend.
Old Jun 2, 2006 | 12:17 AM
black58's Avatar
black58
24 hour access to NAPA? Wow must be nice!
Old Jun 3, 2006 | 07:12 AM
Tech-man's Avatar
Tech-man
Smile
It is! I also work at NAPA and it is only 4 blocks from home.
Old Jun 3, 2006 | 11:21 AM
S.N.A.F.U's Avatar
S.N.A.F.U
Wink
Same here man bout 4-5 blocks away and the employee mark up is a beautifull thing.The best parts dirt cheap.I even get a small break from Ford(small).
Old Jun 3, 2006 | 01:09 PM
petes79f150's Avatar
petes79f150
HEY! NO FAIR! By the way, I need a set of Clevite main bearings part number......
