will this carb work?
Old Jun 1, 2006 | 12:50 AM
ibleedblue1385's Avatar
ibleedblue1385
would a holley 650cfm double pumper be to much carb for a 302 roller motor?
Old Jun 1, 2006 | 07:14 AM
cujo8's Avatar
cujo8
The 650 may be a little on the large side especially since it is a double pumper version. I think a 600cfm with vacuum secondaries would be a better choice, be more responsive and give you better fuel economy if you stay out of the secondaries. I used a cfm calculator for my 302 engine and the results came back at 350cfm. That is why I recommend the vacuum secondary carbs, since the primary side will be great for around town and when you need to pass just hit the gas and the secondaries will open and you will have all the power you need. Double pumpers have mechanical secondaries and are better suited for all out race applications and not fuel economy IMHO.
Jim
Old Jun 1, 2006 | 12:51 PM
ibleedblue1385
thats the thing I am not worried about fuel economy, I just want the most performance. I can get a 650 double pumper real cheap, and right now I have a edelbrock 600. Would I see a performance difference between these two carbs?
Old Jun 1, 2006 | 01:04 PM
cujo8's Avatar
cujo8
It's hard to say w/o knowing the history of these carbs just how much difference you will see between them. If they both where new perfectly setup carbs the 650 would probably have higher top end at WOT, but the smaller CFM carb could have a quicker low end range due to the higher air velocity through the venturies. Where are you looking for performance improvements....or in other words how are you going to use your vehicle (is this a truck)?
Old Jun 1, 2006 | 01:24 PM
ibleedblue1385
yes its a 4x4. I guess looking for improvments top end. My edelbrock has good low end response but at high rpm's with the 4 barrel open it kinda falls on its face. almost has more power if I back off the throttle a little. And I can't stand that. Any thoughts? If I get the Holley I am going to buy one of those holley performance books, rebuild it, and dial it in.
Old Jun 1, 2006 | 02:43 PM
cujo8's Avatar
cujo8
This condition makes me think the performance limitation might not be the carb, but an engine breathing problem. A cam and exhaust upgrade maybe what you need. The engine can only breath in as much as it can exhale out and if your cam lobe lift is small or your exhaust is too restrictive, changing your carb will not help on the top end. Many people who are trying to boost their stock engine performance opt for an aftermarket intake/cam package and slap on a set of headers with a dual exhaust. What other modifications have you made so far on your engine?
Jim
Old Jun 2, 2006 | 12:15 AM
ibleedblue1385
Ok well its got an open 14" edelbrock cleaner, and bbk shorty headers into 2 1/2" duals w/flowmasters. So breathing is not the prob. unless you think I can get more air flow from a foam edelbrock filter? The motor is fresh with ported e7's. Complete MSD ignition. It feels like carb. But I could be wrong.
Old Jun 2, 2006 | 07:01 AM
cujo8's Avatar
cujo8
What do you have for an intake manifold and cam? These two components also determine how well the engine will breath. You can have the best carb and exhaust on your truck, but if there is restrictive flow through the engine it will only breath as well as the restriction allows. Its like the old saying "the chain is only as strong as its weakest link".
Jim
Old Jun 2, 2006 | 12:56 PM
ibleedblue1385
I have an edelbrock performer intake. Stock roller cam from a 92' stang.
Old Jun 2, 2006 | 01:18 PM
Kemicalburns's Avatar
Kemicalburns
install some 1.7 roller rockers that will wake that cam up. also for a 4wd app the holley's tend to be problem ****. they flood easy and go thru power valves like crazy. try and edel 600 or 625 .
Old Jun 2, 2006 | 03:20 PM
johnsonswamp's Avatar
johnsonswamp
The cam will be your problem, your engine can only make power in the area that the cam allows.
Also on an overdrive transmission Holley doesn't recommend the double pumper series carbs, if you have an over drive.
Old Jun 2, 2006 | 04:52 PM
BroncoRoadKill's Avatar
BroncoRoadKill
I have a 580 holley street avenger on my new 351w in my bronco and it runs like a bat outa hell.
Double pumpers are strickly for dragracing where you mash the gas and the secondaries open quickly so they need fuel as fast as the primaries do.
vaccum secondaries open slowly and they get there fuel as fast as they need it, as they are better for street, and much more drivability.
Old Jun 3, 2006 | 03:07 PM
ken75ranger's Avatar
ken75ranger
There's your problem, The stock cam is good to around 4500-4700 rpm. Not a bad truck cam but your not going to get any top end out of it.
