Installing Ranch Hand Grill Guard
Old May 28, 2006 | 03:06 PM
jplyon's Avatar
jplyon
I have a ranch hand grill guard I am trying to install on my 1996 cc 4x4 deisel. I can't seem to figure out how the brackets go. Can someoen help? Does anyone ahve photo's of the process?
Old May 28, 2006 | 07:41 PM
TexasGuy001's Avatar
TexasGuy001
I have the same grille guard on my truck. I dont have any pictures but I'll see if I can get some. Do you have 4 brackets? The 2 flat ones mount between the bumper and the frame with the mounting holes towards the outside of the frame. You then drill holes in the bumper where the bolts will go through and then the sort of L shaped brackets that go from the flat brackets at the frame down to the bottom of the grille guard. You have to remove the front bumper to install the brackets. Then reinstall the bumper and then finally the grille guard goes on last. I believe there are 6 additional bolts with the guard. Once you see how it goes it makes sense, but I know it was slightly confusing the first time I saw the brackets etc. I hope my explanation makes sense and helps.
kalebc2
Aug 6, 2015 10:05 PM
XPD77
6.7L Power Stroke Diesel
Jan 31, 2014 07:57 PM
A/Ox4
Jan 14, 2012 10:26 PM
Dad's Old Truck
Oct 19, 2011 05:49 PM
A/Ox4
May 20, 2011 02:49 PM
