windshield install
Old May 27, 2006 | 09:56 AM
dstruble's Avatar
dstruble
windshield install
Is the rubber cement really necessary when installing the windshield??? Is it for sealing purposes or for installation ease??? I will use the soap solution to help the install. Thanx for any help !! BTW truck is garage kept if that matters?
Old May 27, 2006 | 10:30 AM
Randy Jack's Avatar
Randy Jack
ds -
Apparently, the rubber cement isn't necessary. I just removed the windshield from my 56 and it had no cement. It's been in there for at least 10 years and seen a lot of rain with no problems.
Old May 27, 2006 | 11:39 PM
mark914's Avatar
mark914
i recently installed a new windshield in my 56 and didn't use cement. It has sat out in the rain a couple times since then and no leaks. soap and water on the gasket definitely makes installation easier
Mark
Old May 28, 2006 | 12:14 AM
CIAF's Avatar
CIAF
The pro shops use linseed oil and it takes all of 20 seconds to rope it in and seat real good. No sealers, just use a new gasket with each new windshield.
Old May 28, 2006 | 12:46 AM
51ford fan's Avatar
51ford fan
I installed a new windshield in my 51F1 without any sealer and it leaked in the lower corners when moving, it was ok when sitting. I have sense put the glass sealer from Napa around it and it's ok now.
Rod 51F1
Old May 31, 2006 | 12:06 PM
53fatfndr's Avatar
53fatfndr
If it is a new gasket you don't need sealer. I had my windshield installed by the place I bought it from and the guy who installed it told me that the gasket I had (bought from Mid-Fifty) was a "self-sealing" type of gasket. However, he said if it leaked, it would need sealed. My truck only sees sunny days, so I don't know if it will leak or not
Old May 31, 2006 | 02:39 PM
fking1's Avatar
fking1
My 55 recent install, no cement.
Fred
Old May 31, 2006 | 03:33 PM
kooper909's Avatar
kooper909
Same with my '60. It's parked outside and gets driven in the rain frequently with no cement and no issues.
