Wind Intrusion
Old May 26, 2006 | 11:46 PM
FordFan530's Avatar
FordFan530
Wind Intrusion
Hey guys,
My 2005 F-150 supercrew has a wind noise coming in on the upper right portion of the windshield (passanger side). Its wind noise that you should hear with a window down, but all windows are up and u can still hear it goin 70mph on highway. There's obviously something wrong, because you cant hear it on the driver side. I've been to a Ford Service Center and they said they fixed it, could still hear it, then went back and they attempted to fix again...still hear it on highway. Any ideas, I could really use some help! Thanks.
FordFan530
Old May 27, 2006 | 06:21 AM
96f150's Avatar
96f150
Welcome.....Try using the search function as, there is many posts on this topic.
Old May 27, 2006 | 05:57 PM
hllon4whls's Avatar
hllon4whls
A tip that I saw on an car TV show was to take a piece of paper to see if it was particually loose in any area where the door seals would be. You can also use a smoke detector to try to blow a small amount of smoke through the seams and even near the glass. If it comes from the inside to the out, you have found your leak.
For the cheaper trick, close the door on the paper and make sure that it is not loose anywhere in the door seal.
I find my new 150 to be very very quiet for wind noise. Hope you can fix yours.
tolliewolly
6.7L Power Stroke Diesel
Aug 13, 2014 04:27 PM
tolliewolly
21
Sep 2, 2013 08:22 PM
BMLocal175
2004 - 2008 F150
Apr 21, 2007 06:54 PM
ojosdestranger
1983 - 2012 Ranger & B-Series
Nov 19, 2004 11:01 PM
