Short Box Switch
Old May 26, 2006 | 01:32 PM
emgee's Avatar
emgee
Question Short Box Switch
I've got an '80 F100 styleside short box needing lots of bodywork on the box.
I have a chance to get a minty '88 short box and I need to know if I cut out the smooth, flared arched wheel openings I can replace that sheet metal with panels from an '80-'86 short box (from let's say, LMC). To me the design is the same except for the arch so if you go 2" either side of the opening you should be able to do this.I'm sure the inner fender can be made up. Anyone know if this sounds right?
Old May 28, 2006 | 10:11 AM
cdd5599's Avatar
cdd5599
Ya it will work!, however that is a lot of work. I took a 1989 long bed and welded on two hole new (1986) bed sides. It was easy except for making sure you center the bedside so that your body lines match up. I have seen a lot of guys just put a 1988 bed on their 80-86, and even though the wheel opeings didn't match it still looked alright.
I agree that it looks better when the front and rear match, but is is a lot of work.
later,
chuck
86F150_4X2
Oct 23, 2018 06:21 PM
emgee
Paint & Bodywork
Feb 17, 2015 10:14 AM
Gearstix
Paint & Bodywork
25
Jan 23, 2009 08:54 AM
cjf5150
Paint & Bodywork
13
Aug 14, 2007 03:09 PM
timothy47129
Dec 28, 2005 06:02 AM
