351C into a 86' 4x4...
Old May 26, 2006 | 01:04 PM
ibleedblue1385's Avatar
ibleedblue1385
Hey everyone here is the deal. I built my first motor about 1 year ago, its 302 roller block, stock bottom end, heads ported and milled, edelbrock intake & carb, eaders, and a complete msd 6 ignition. All mated to a brand new c6. Love this motor it pulls hard even with 35's and as beaten any tbi 350 chevy i have ran against. The thing is I love building motors and I love Ford. So when I get back home(attending mmi) I am going to build another motor for this truck. As of right now I am 90% sure I want to go with a 351c. It will be unique and no one else will have one, and I like that. I do plan on using the 2V heads. What I am asking is perhaps what recipe could I use to get this motor to perform it best in 4x4 truck. As far as pistons and cam goes, any head work, intake and carb combos that would work the best?? Any pointers will be greatly appreciated. Thanks.
Old May 26, 2006 | 04:05 PM
Torque1st's Avatar
Torque1st
Posting Legend
Forget the 351C and go with a 400"Cleveland" instead. It will do much better in a truck.
Old May 27, 2006 | 12:39 AM
ibleedblue1385
if you are refering to a 351M/400 that is out of the question. I am not changing transmissions, mine is brand with shift kit and all. The C6 stays. I asked about the 351C not the 400. Does anybody have any opinions on what could be done the 351C to make it a good truck motor?
Old May 27, 2006 | 01:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
All 400's do not have the large bell pattern.
For a 351C run a diff to keep your RPM's up. Build a 351C for torque which it is not really good for. The 2V heads and a small cam would be a good start. The 351C was a good engine for light vehicles like mustangs. They were used in trucks in Australia.
Do you already have a 351C? Otherwise do something really different get a 400 with a small bell pattern to fit your transmission. Check with TMI, they just built a 434 stroker with a small bell pattern for a Pantera. You may need to go with a different cam to move the peak torque lower.
Old May 27, 2006 | 12:41 PM
grclark351's Avatar
grclark351
there's nothing wrong with a Cleveland for torque. the 351M is a truck engine, what's the bore and stroke? what's the bore and stroke of the Cleveland? same heads. does a heavier crankshaft and longer rods make more torque in an otherwise nearly identical engine? the width of the intake must be what does it, or the length of the pushrods? wrist pin diameter?
with the right pieces for the desired outcome a Cleveland will make torque, with less reciprocating weight and rotating mass. don't believe the magazine articles.
Old May 27, 2006 | 12:53 PM
ibleedblue1385
everyone says 351C's dont make good torque. but 302's do? I am sure a stock 351C is putting out as much or more torque than a stock 302 and ford used 302's in millions and millions of trucks. I want to eventually build a 400 for a 73'-79' F150 4x4 that I would one day like to also own. I have heard a 400 with a small block bellhousing are really hard to find if not impossible??? No I do not already have the block but no many people that would have a few laying around.
Old May 27, 2006 | 02:36 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have driven many different 302 and 351C and 351M builds and I am not a fan of those engines in any heavy vehicles (large cars or trucks). They just have no low end grunt to speak of. This is personal experience not magazine articles. In fact I can't recall reading any magazine articles on the subject. I don't like wheezers either but feel they at least have some potential and are readily available unlike the 351C. To each his own tho, have fun!
Old May 27, 2006 | 09:50 PM
dinosaurfan's Avatar
dinosaurfan
351C in a truck
BlueBleeder, I have to agree with EricTorque on this one. and if you start reading some of our forums, you'll see that he and I usually are on the opposite sides of an issue. yes, the 351C can do what you want it to do. If you think you just have to have one, get some flattopped pistons and use the 2V heads and a dual plane intake and headers on the exhaust, with a healthy hydralic cam. But the guys who have a 400 and do the same things are going to be faster than you are. The guts from the C6 you have now could be put into another patterned case, or you could search out an earlier 351M/400 that has the smaller bell pattern on it. Yeah, Ford put the 302 into millions of trucks, but that doesn't mean that we should do it. before you choose the 351, drive some other trucks that already have a built 400, and see if they don't offer the feel that you want. DF, @ his Dad's house
Old May 28, 2006 | 12:13 AM
ibleedblue1385
I dont know what the hell you people did not understand about what I said. I said I AM going to be using a 351C. Did you not read this? Do you just like to argue which is better?? I DID NOT ask you which motor you would use or which you think is better. I understand the 400 is torque motor. OK. I just asked what could be done to the 351C to make good torque. Was it that confusing????
Old May 28, 2006 | 01:28 AM
Torque1st's Avatar
Torque1st
Posting Legend
I already told you what to do with the 351C to give it better torque (see post #4). It just is not a torque motor. It is a poor choice, but it is yours to make. Have fun!
Old May 28, 2006 | 02:13 AM
Brian S's Avatar
Brian S
Actually you said 90% sure, which left 10% doubt.
If you're willing to spend the money you can have your cake and eat it too. Have you considered a 393/351C stroker? Compared to a 400, the power difference would be negligible.
It may be helpful to read this article from KEC.
Torqueing Sense
http://www.kec.com.au/articles.html
Old May 28, 2006 | 08:05 AM
danlee's Avatar
danlee
I think that a 351C would make a respectable truck engine. Of course cubic inches are King. A 460 or similar motor will make loads of low RPM torque, but there are many 351W powered trucks on the road.
If I wanted to build a 351C truck motor, I would not use 4V heads. My first choice would be an alloy head like the CHI-2V. Next would be an Aussie 2V head, and third would be a 351C-2V open chambered head.
The 351C examples in the link in Brian's post haqve way too much cam duration for a truck motor. I would selact the venerable Comp cams 255DEH or a Hydraulic Roller with similar timing.
To tie it all together, I would pick pistons that gave me a reasonable DCR. These would have about 15cc dish/valve relief, to give ar CR of 9.27:1 and a DCR of 8.0:1. This is a conservative CR for alloy heads and quench chambers. I would really like to get more lift out of the 255DEH cam with CHI-2V heads. A hydraulic roller would help.
Old May 28, 2006 | 08:35 AM
havi's Avatar
havi
I'll have the Roast Duck
and to add to torques #4 post, go one gear lower than recommended for your tire size, this will bring up your rpm's into the powerband the 351C is known for.
Old May 28, 2006 | 10:39 AM
danlee's Avatar
danlee
Originally Posted by danlee
I.
I made a mistake, it should be an 11cc dish with the 64cc CHI heads. 15cc will work for Edelbrock 60cc heads. The dish should be even larger for Aussie iron heads. The 351C-2v open chamber heads have about 75cc chambers and should be OK with a flattop piston at stock CH.
If you have some particular combo in mind, let me know and I'll run a few simulations.
Old May 28, 2006 | 12:14 PM
ibleedblue1385
thank you danlee for your responses. I will write them down. Just out of curiosity when were the small bellhousing 400's made? I would like to build one, but figured i would wait till I got an older truck.
