EGR - where does it hook up?
Old May 25, 2006 | 01:55 AM
Hellbore's Avatar
Hellbore
I have a 76 ford F150 with 360 CID FE engine.
I am wondering if I have the EGR trigger vacuum hooked up correctly.
On my engine, the EGR has a spacer between the carb and the intake, and vacuum causes EGR to kick in, opening up for exhaust gas to go into intake.
What I am wondering is, where to hook up the EGR vacuum trigger. I think EGR is supposed to kick in during low to medium accelleration, then cut back out for high accelleration.
Would that mean you hook it up to "spark" on the carb, or should there be a separate hookup for it?
I'm just not sure what is goin on, because right now I have it hooked to spark, along with my vacuum advance (using a T connector) and the engine is having problems, I wondered if EGR is part of it.
Also my carb has 2 connetions that I do not know what they are for. I am using the connection on the passenger side for spark, I think that is spark, but there is also a connection on the front driver side corner that is unknown to me, and there is also a small nipple on the BACk of the carb (next to the PCV hookup) and this small nipple doesn't seem to ever be pulling vacuum.
I bet my carb is somehow hooked up wrong... in fact I think I need to pull it and try to figure out what all these connections are FOR...
BTW I think the carb is a Motorcraft 2150, 351 CFM, but the tag is lost so I can't be sure which carb it is.
Old May 25, 2006 | 03:55 PM
ford390gashog's Avatar
ford390gashog
the egr does not go to the saprk port. the egr runs to full manifold vacuum with a heat switch inline that gets screwed into the intake manifold. if you don't have smog then just don't hook up the egr.
Ar. Hillbilly
Nov 3, 2016 08:12 PM
dtkkc
Sep 23, 2016 04:49 PM
BTFordGuy302
20
Apr 15, 2016 06:56 AM
Hellbore
May 24, 2006 10:31 PM
MARC
Jan 12, 2005 11:04 PM
