compressor wheel
Old May 26, 2006 | 08:55 PM
Bin Strokin's Avatar
Bin Strokin
sorry it says it supposed to increase airflow but maintain the same psi, one of the sites says it increases airflow by 50%, but look here.
http://www.xtremediesel.com/index.as...ROD&ProdID=260
or
http://cgi.ebay.com/ebaymotors/Ford-...spagenameZWDVW
Old May 26, 2006 | 09:49 PM
ryaneverk2's Avatar
ryaneverk2
Well, I'd have to say that their descriptions seem a little inaccurate. It doesn't increase air flow. It shifts the surge line to the left on a compressor MAP, as it is more efficient, but it does cost a couple psi of boost.
If you want to buy the wicked wheel/superior wheel/whatever it's called then I'd definitely suggest buying it from a site sponsor, and staying away from the Ebay ads for them.
Old May 26, 2006 | 10:10 PM
pmasley's Avatar
pmasley
Question
Originally Posted by strokin_it7.3
that 2-3psi drop is well worth the sound! plus that alleviates some drive pressure on all-a-y'alls .84AR tiny exhaust housings
Strokin, I have been told that IH used a bigger turbo on the 7.3's that were installed in the school busses. I have acces to one. Wonder if it will work?
Old May 26, 2006 | 11:36 PM
Bin Strokin
ok well anyway if it does drop psi, do u notice a power loss with the WW over stock. i know it eliminates surge and sounds better but is there a difference in the way it performes? pros and cons.
Old May 27, 2006 | 12:08 AM
ryaneverk2's Avatar
ryaneverk2
I can't really comment on what the difference in power is or feels like. I'd imagine it'd feel a bit more sluggish.
Are you experiencing surge that you want to get rid of, or just looking at the wheel for the sound? If it's the surge, you can install an ATS housing which will cure the surge without any psi loss.
Old May 29, 2006 | 12:06 AM
jtharvey's Avatar
jtharvey
The turbo on the school bus is most likely the same as the van turbo, a non wastegate, 1.15 A/R exhaust housing turbo. If it's the same center section, it should work. If you can get some pictures of it, load them to your gallery, we'll be happy to take a look at it and let you know what we think.
Old May 29, 2006 | 12:11 AM
pmasley's Avatar
pmasley
JT, if I understand your post, the van turbo is different. How?
I see the non wastegate part. How does it relieve the pressure without a wastegate?
Old May 29, 2006 | 12:27 AM
jtharvey's Avatar
jtharvey
The only difference between a van turbo and a truck turbo is on the exhaust side of the turbo. The van turbo has a slightly larger turbine wheel, and a larger 1.15 A/R non wastegated exhaust housing. The stock truck exhaust housing is a smaller 0.84 A/R.
Due to the larger exhaust housing, it doesn't need a wastegate. The wastegate on the truck turbo housing is to bleed off excess exhaust pressure once the boost gets to a certain point. If the smaller truck housing didn't have a wastegate, the turbo would have too much backpressure, and could cause damage to the engine. However, the larger housing on the van turbo doesn't build anywhere near the backpressure of the truck turbo, so it doesn't need a wastegate to bleed off the excess pressure.
The drive pressure to boost pressure ratio on a stock truck turbo is about 2:1. So, if you've got 20 pounds of boost, you've got about 40 pounds of backpressure. But the van turbo has a ratio of about 1:1. So, the van turbo is much more efficient than the truck turbo. You'll probably see peak boost numbers go down a little bit, but you'll actually be making more power because the turbo is more efficient, since the engine is not having to work as hard to push the exhaust gasses out and through the turbo.
Old Jul 11, 2006 | 04:07 PM
HideOut's Avatar
HideOut
I was looking for th is exact info, mostly about installing the WW/Banks. if it looses power them I'm NOT going for it. Im not alieviating surge, im looking for more cost effective power and MPG. The buss/van option sounds nice. Anyone know of a posting anywhere that it was done in with before and after numbers/info?
Thanks,
HideOut
Old Jul 11, 2006 | 04:57 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i dont think the T444E has a larger exhaust housing. (maybe) on the higher Hp models. however most of them are used for delivery and busses and they need to spool quick. here is a picture, it isn't a drop in installation
Old Jul 11, 2006 | 05:44 PM
pmasley's Avatar
pmasley
It looks like it is painted Ford Blue and I have to put up with that terrible looking gray that they have been using for the past 15 or so years.
Old Jul 12, 2006 | 11:06 AM
wants_a_power_stroke's Avatar
Does the Banks turbo housing (Quik Turbo or whatever it's called) work better with the banks/ww than stock? I can get a Banks turbo and wheel for a song out of a wrecked F-250 (just installed before the crash) but if it won't make much difference I'll just stick with doing the WW.
Old Jul 12, 2006 | 01:09 PM
  #28
ryaneverk2's Avatar
ryaneverk2
The Banks housing is for the turbine (exhaust) side, as opposed to something like an ATS housing which is for the compressor side. The Banks housing plus wicked wheel together should take care of any surging... yeah if going that route I'd do both together.
I should further say that what I mean is that the banks housing OR wicked wheel alone probably won't take care of surge altogether.... however, the two in combination WILL. Or, an ATS housing. Banks housing plus wicked wheel may have slightly less boost then banks housing and stock wheel, but it will do a better job of handling surge.
Old Jul 12, 2006 | 01:30 PM
  #29
FLASH 13's Avatar
FLASH 13
it sounds like the the thing to do is buy a van turbo!!!! is this a bolt on mod or is their much fabrication? van turbo sounds like the complete solution
Old Jul 12, 2006 | 11:22 PM
  #30
Kwikkordead's Avatar
Kwikkordead
I looked on thier website and couldn't find any info on the turbo.
