Sponsored by: Real Truck
Sagging Rear End
Old May 24, 2006 | 03:17 PM
GREGSCOTT's Avatar
GREGSCOTT
Sagging Rear End
I have a 2001 F250 SuperDuty with a V-10. I have a dump insert and carry loads all the time. The back end of the truck sags quite a bit. Any simple/inexpensive solutions?
Thanks!
Old May 24, 2006 | 03:40 PM
scratcherky's Avatar
scratcherky
Do a search for Timbrens and see what you think. They wiil not help sag when your truck is unloaded. They only work when truck is loaded therefore do not affect ride quality when truck has no load.
Old May 24, 2006 | 03:42 PM
devildog_0431's Avatar
devildog_0431
So after you dump your load are you saying your truck sags lower than it originally did if new ? kinda like worn out springs/shock sag ? get an add-a-leaf for the rear and thicker shock oil.
Old May 24, 2006 | 03:47 PM
biz4two's Avatar
biz4two
Arrow
Thanks!
You can install a set of F350 4" blocks in the back. Make sure to get the blocks that have the same setup as your SD. IE: wheel base, CC, SC, etc.
Does your SD have the Overload spring? If not, you can install one and that will help with the sag.
Take a look at this thread here at FTE...
https://www.ford-trucks.com/forums/s...d.php?t=492845
URL: http://www.activesuspension.com/
Hope these idea's help...
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old May 24, 2006 | 06:00 PM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
biz
You can buy them from me if you like...
mossyoakford96
Mar 13, 2012 12:27 PM
7.3lpowerstroke
Oct 22, 2011 01:11 PM
ncinirator
Paint & Bodywork
Jul 14, 2007 02:13 PM
NyXterrainF250
Apr 1, 2007 06:53 PM
Thoth88
1983 - 2012 Ranger & B-Series
Jun 18, 2004 11:09 PM
