I know that the resistance is the key part. Less ohms per foot is desired, but are some manufactured 8mm plugs a lot higher resistance than others? Ive heard that 500 ohms is good enough for performance. With the 40,000 volt electronic setup will these work o.k.?
I've got the pertronix setup with the flamethrower coil(ver. 1) and I'm using the standard plug wires computer listed for my truck from "pepboys". Everything works great.
