Injector harness resistance check
Checked the resistance of the injector harnesses at the 42 pin connector and have high resistance on 6 of the 8 injectors. #4 and #5 read 3.1-3.2 ohms, #2, #6, and #8 read 8.5-8.6 ohms and #1, #3, and #7 read 20.5-20.9 ohms. I plan on pulling the valve covers and checking resistance at the injectors to eliminate a possible bad coil before replacing VC gaskets, UVCH's, and glow plugs.
What type of symptoms will this cause? Loss of power, rough idle, poor fuel economy?
That's what I was thinking. If the valve covers are coming off, new gaskets, UVCH's, and glow plugs are going in.
Jay Fletcher
04-07-2013 10:33 AM
