E85 and Edge Evolution???
Old May 24, 2006 | 12:53 PM
guerrero101's Avatar
guerrero101
Hello Everybody,
Has anyone tuned an F150 using E85 with the Edge Evolution??
Just wondering what kind of performance gain one would get since from what i understand E85 has higher octane (105) rating than premium gas.
Old May 24, 2006 | 02:05 PM
CTford's Avatar
CTford
Hmmm... it's not just octane level but also the amount of fuel needed. Could the injectors withstand that load? I don't know. Would you get premature firing because the 15% gas in there doesn't have 105 octane? Again I don't know. Also, E85 by itself knocks down your milage by about 25%, so with a tuner it would be an insane drop. But if these problems can be overcome, I think it would be great to try.
Old May 24, 2006 | 02:09 PM
92merc's Avatar
92merc
Not necesarrily true. I think if you ran the high performance tune, the 92? or what ever is listed and then add in E85, the time will have been increased even more. I'd bet you'd get not only performance, but most of your mileage back.
Old May 24, 2006 | 03:02 PM
rusty70f100's Avatar
rusty70f100
My thinking was unless you have a flex fuel vehicle, you probably shouldn't be running E85 in the first place.
Now, if you do have one of the new Flex Fuel F150's, is there an Edge or similar tuner available for it, and is it different than the regular tuner? Would the regular tuner be compatible with the Flex Fuel F150?
Old May 24, 2006 | 04:25 PM
Belly's Avatar
Belly
I'm on my third tank of E85 and have been running the Edge Tuner. The first two tanks the Edge was set at level 2. I did not notice any difference in power and all worked fine. I set the Edge at level 3 on my last fill up of E85 and it's working just fine. I've been using the standard tuning and haven't modified anything. I've posted my MPG in another post and I'll update that post when I refuel.
Old May 24, 2006 | 08:08 PM
yellow98cobra's Avatar
yellow98cobra
I would tell you to Email Edge or Discount Power Parts and ask. BUT Niether of them will answer your emails.
Old May 24, 2006 | 08:35 PM
Belly's Avatar
Belly
Here is the response I received from Edge before I used E85-
There should be no problem running a higher octane fuel with the Evolution. If you run level 3, I would just monitor how the truck responds, if you get any knocking or detonation you may need to program to a lower level or adjust the timing down to eliminate the knock. We do not test with E85, as it is not available here. If you have any further questions, let us know.
Old May 25, 2006 | 07:35 AM
db_tanker's Avatar
db_tanker
I have heard that the reason why E85 wasn't suggested for the non-flex engines was the spark timing? And wouldn't this be adjusted with a tuner?
D
lkfldredneck
Sep 4, 2016 10:04 AM
RV_Tech
Aug 1, 2016 05:35 AM
Kochrane
Computer Chips & Tuners
Sep 3, 2012 05:37 PM
jl4407
Jan 13, 2012 09:24 PM
hndamxmn
Jan 9, 2009 06:20 AM
