Knocking noise coming from engine
Old May 24, 2006 | 10:28 AM
Ford5726's Avatar
Ford5726
I have a 04 5.4l and at idle I hear a really loud knocking noise coming from the engine. I went to Autozone and they said it may be that I am running too thin of oil, I am running 5w20. Does anyone have any suggestions?
Old May 24, 2006 | 12:15 PM
FS-150's Avatar
FS-150
Do you hear the noise only at idle?
Old May 24, 2006 | 12:29 PM
pjbonthebeach's Avatar
pjbonthebeach
The noise is likely the Cam Phasers (Left and Right). The TSB is 06-4-7 and, if not covered by warranty, costs $1,122 to correct. In effect, they are replacing both camshaft gears. If you are not covered by the warranty, I would not have it done. I got mine in just under the 36K limit.
Old May 24, 2006 | 12:52 PM
KevinM's Avatar
KevinM
Knocking noise could be the cam phaser problem as per TSB 06-4-07. The oil should not be the problem!
Old May 24, 2006 | 01:14 PM
The Oldtimer's Avatar
The Oldtimer
I have a noise like that from time to time, not very often, only at idle when my truck is in gear. If I put it into neutral or step on the gas, it goes away. Could that be the same thing?
Old May 24, 2006 | 01:45 PM
pjbonthebeach
Mine showed up all the time but was subdued when warm. The problem made my truck sound like it had a diesel (albeit quieter), especially when initiating a slow acceleration while cold.
fordman19762003
Modular V8 (4.6L, 5.4L)
Dec 6, 2012 10:50 AM
evilwayz7
2004 - 2008 F150
May 8, 2012 06:22 PM
blloyd
17
Nov 19, 2007 05:59 PM
Luling
Apr 22, 2006 01:54 PM
Ranger256
Escape & Escape Hybrid
Dec 30, 2005 01:41 PM
