Is this a good idea?
Old May 26, 2006 | 01:16 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by 85-89ford
Thanks for all the reply's everyone. These trucks are in rural Oregon so I'm not to be concerned about the smog stuff it will probably all fall off very soon. If we go the carb. route what parts should we keep from the 89 motor. thanks
With all due respect, I would be concerned if I were you. California's Crappy ideas are spreading north, and east. Just ask the people in Portland.
I would keep all the smog stuff in a box, for possible future use at least. Just incase.
Just my opinion.
The trends that are happening in parts of Arizona, Tennesse, Oregon, Nevada, etc... seem very familiar to what happened here in California back in the 80's. It all started in L.A. you see. Just like I predict that the treadmill test will be required statewide here in 5 to 10 years.
And God knows I hope I'm wrong.
Old May 26, 2006 | 06:04 PM
Rosie's Avatar
Rosie
I have to agree with Navymid08. Stick with the carbed motor. I got away from the efi because i got tired of replacing sensors. Carbs you do have to tweek but the electronics are not near as hard to diagnos. that "check engine" light gets real annoying.
Old May 26, 2006 | 06:18 PM
85-89ford's Avatar
85-89ford
thanks everyone for all your input it seems like the carb engine is the way to go so we will probably do that but we will be putting the 5 speed inthat came with the 89 then figure out which rear end to go with , son wants taller tires and a lift for the truck.
Old May 26, 2006 | 09:58 PM
toyscout2's Avatar
toyscout2
My OPINION, use the original 300. Rebuild it basically stock, but port the heads and add a good 3 angle valve job. Put in the stock cam, add a Offenhowser dual port intake and Holley 4 bbl carb. Like mine!. Lots of torque and decent mileage. I also added a 6AL ignition and coil. Get late model (cant remember the year, 88 or so) split manifolds and put in a good 2.5 inch exhaust (I used a flowmaster muffler). Get a five speed to go behind it and have fun.
Old May 26, 2006 | 11:45 PM
80-F-250's Avatar
80-F-250
ya some late model blocks are like that...,but you can drill them to add the pump
Old May 26, 2006 | 11:50 PM
80-F-250's Avatar
80-F-250
ya some of the late model blocks are not drilled for an mechanical fuel pump,but its really easy if you already have the block toredown to drill it out and add the pump!
Rabbit_F150
Sep 25, 2011 07:52 AM
crash104936221
Jun 26, 2003 11:52 AM
gingerbreadmaniac
Nov 3, 2002 08:39 PM
Sep 26, 2001 12:54 AM
