crossmember rot
Old May 23, 2006 | 09:38 PM
abcat12's Avatar
abcat12
Question crossmember rot
i just bought a 82 f150 sb 4x4. but the x member under the bed is rusted bad and so is the bed. got to love MD winters. What I want to know is there any place other than a dealer to find crossmembers and how would new ones attach (bolts or rivits)? and is it easier to rebuild my styleside with patch panels on both side and a floor or find a step side? I like both styles but if its easier to rebuild i'll fix mine.
Old May 23, 2006 | 09:56 PM
havi's Avatar
havi
I'll have the Roast Duck
start by looking at the sponsors on this site. I think LMC has what you are looking for.
Old May 24, 2006 | 12:36 AM
80-F-250's Avatar
80-F-250
well the x member is a riveted unit but ive replaced one before ! when you remove the bed then drill out all rivets and use grinder and a cut wheel to cut the welds at the seams horizantel with the frame or a cuttin torch works well! then replace the old rivets you drilled out with grade 8 bolts and lock washers then weld the heads of the bolts for insurance...........the best place to find a x member is the wrecking yard......good...luck clay
Old May 24, 2006 | 08:25 PM
abcat12's Avatar
abcat12
thanks for the advice looks like i might have to head to a scrap yard any way to find some other parts
Broncodawg
Apr 10, 2014 01:39 PM
2002fx4122
Jan 13, 2011 07:47 PM
masterguns2003
Jan 24, 2008 04:36 AM
sigtauenus
Apr 20, 2007 12:19 PM
