Hardie Board Siding Question
Old May 22, 2006 | 08:49 PM
weadjust's Avatar
weadjust
I need to replace some cedar siding. I'm looking a Hardiepanel Vertical Siding (4' x 8' sheets from James Hardie Siding Products).
Looking at the stuff at Home Depot it appears to be a cement board.
What kind of blade (skil saw) would you use to cut this stuff and what kind of nails would you use?
Old May 22, 2006 | 08:57 PM
TXPSD's Avatar
TXPSD
It depends on how much cutting you have to do. If it's a lot you will be better off with a masonry blade, but I have cut small quanitites with a regular blade. Regular nails are fine, just be careful near the edges of the boards because they will split.
Old May 22, 2006 | 09:02 PM
GLR's Avatar
GLR
We sided a 2600 sq ft house with the clapboard (horizontal) siding. Used a diamond tip cutter on circular saw, wear a mask and glasses. Went through a couple of saws and lots of blades. We used regular roof air nailer to fasten. This was pre-primed siding, also available in pre-painted.
Old May 22, 2006 | 09:05 PM
Flash's Avatar
Flash
The Hardiplank blades are diamond tipped and cost around $65.00 for a 7 1/4" around here. If you are a professional, Hardi will replace the blade free once worn out. Just send them to Hardi and they send new ones back. I used the 4x8 to replace my columns in front of the house. I will never work with it again. Yes, it is a sheet of concrete and works like too. A sabre saw blade would cut maybe 2" before the teeth were GONE. The carbide tipped blades for my circular saw would cut about 8' before they turned red from the heat. I would buy a throw away saw if you are still contemplating the Hardi. The grit gets into everything and will destroy a quality tool.
Old May 22, 2006 | 09:23 PM
weadjust's Avatar
weadjust
I don't have alot of area to put the siding on. Two gable ends 3 sheets each end and one area with about 5 sheets.
$65 bucks for a saw blade is kinda steep.
What is your over all opinion on using the hardi board over the regular hardboard siding? Is it worth the extra cost (minimal for my project) and ease of install?
Old May 22, 2006 | 09:37 PM
okst1's Avatar
okst1
My brother sells tons of Hardie plank to builders. According to the builders, they go buy a cheap circular saw at Walmart and throw it away after each job. He also said they just use the blade that comes with the saw.
If you are using hammer and nails you will have to pre-drill holes.
Old May 22, 2006 | 09:51 PM
jake00's Avatar
jake00
rent a concrete gas powered saw?
Old May 22, 2006 | 10:18 PM
TXPSD's Avatar
TXPSD
for the amount you are doing a regular saw will be fine. Yes, the hardi board is definitely worth the cost. It will last years longer than regular siding and being a cement based product it is not combustible.
edit: I also agree with the mask and eye protection. The dust is really nasty with any hardi product. (siding, backer board)
892504x4
May 28, 2019 08:36 AM
tjc transport
Sep 13, 2015 03:02 PM
Nitramjr
19
Jan 2, 2010 09:57 PM
aerocolorado
17
Apr 15, 2009 02:56 PM
weadjust
13
Apr 24, 2005 09:51 PM
