chainsaw-weedeater motors
Old Jan 16, 2002 | 04:01 PM
DrFord's Avatar
DrFord
I never really thought about this much untill I tore into mine. on a 2-cylce engine such as a chainsaw or weedeater, how does the bottom end(crank-rod bearings) get lubricated? there is no oil down there. Or there isn't in any of the ones i've seen :P
Old Jan 16, 2002 | 05:10 PM
Ultramagdan's Avatar
Ultramagdan
[updated:LAST EDITED ON 16-Jan-02 AT 06:12 PM (EST)]As the piston goes past the intake port fuel mix still flows and thus goes to the crank area. The reason you may not have seen any lubrication is most of the mix is gas and has evaported off or was burned. There is still a film of oil present. Not much but it's there.
If you could see a 3D image of a 2 stoke motor in motion it would be clearer. There is a reason for the size and shape of the ports on the cylinder wall.
There is never much lub down in the crank area - rather a film of mix on the surfaces while the motor is running.
Old Jan 16, 2002 | 06:17 PM
Cowboy_351's Avatar
Cowboy_351
rats after i read the title of this post i thought it might have been something else about C*evys
Old Jan 16, 2002 | 09:14 PM
Ultramagdan
Now that is GOOD!
Old Jan 16, 2002 | 11:50 PM
Greywolf's Avatar
Greywolf
Two-Cycle engines carry the lubricant in the fuel-Air charge itself. This is why they are so "smoky"....
It's also why the plugs foul so often.
The bottom end acts like a compressor, and pushes the recieved fuel into the cylinder through a bypass that is uncovered as the piston travels down...
The reason you have a specific mix that is needed for your engine is because the manufacturer has to balance what a "burnable" mixture should be, against the lubrication of the lower end bearings (usually ball, or roller bearings).
Another point worth mentioning, is that if a 2-cycle is left unused for too long, the oil in the bottom of it can become "gummy", and not work so well.
For this reason, you should be careful when you store one for a long time. Sometimes it helps to ground the plug, and spray WD-40 into the carb, then pull it through a few times to clean it out.
-Hope I helped some...
~Wolf
Old Jan 17, 2002 | 12:21 PM
Mil1ion's Avatar
Mil1ion
cpnhgnjnky
May 22, 2007 07:01 PM
e1p1
16
Oct 25, 2005 10:58 PM
jjoel
Sep 4, 2005 12:38 PM
pchristman
13
Oct 3, 2004 12:17 PM
GammaDriver
Feb 10, 2002 12:15 AM
