Are all DOHCs interchangeable?
Old May 22, 2006 | 03:25 PM
mdbayler's Avatar
mdbayler
I've been doing some reading about the Modular 4.6 engines and I've seen information about them being manufactured in both the Windsor and Romeo plants. From what I've read there are interchange issues between engines built at the two plants.
Were all of the DOHC engines (Cobra, Mark VIII, etc.) built in the same plant, or was the production of the DOHCs also split between the plants? I'd like to put together a DOHC that looks like a Cobra, but it seems like it might be easier to find the engine out of a Mark VIII and add the Cobra intake and trim accessories if they will interchange.
I understand that there are internal differences (at least the crankshaft material and cam duration/lift), but do the parts interchange between all of the DOHC engines?
Mike Bayler.
Old May 22, 2006 | 11:42 PM
LxMan1's Avatar
LxMan1
I believe that All DOHC engines are built in the Romeo plant.
I'm not sure about internal differences. They both run pretty good.
Old May 30, 2006 | 12:37 PM
mat-helm's Avatar
mat-helm
The reason they don't put DOHC's in trucks is becase they don't make as much torque as the SOHC's...
Old May 30, 2006 | 08:31 PM
kspilkinton's Avatar
kspilkinton
Perhaps you mean to say the current tune the DOHC's use don't produce torque in the range a truck would be more suited to use.
Remember the DOHC 5.4s were available in Navi's, a 5800lb (empty) vehicle. They produced slightly more torque and hp than the SOHC 5.4 version available in 2003, it's just that the peak numbers were a bit higher in the rpm band. The curves were actually relatively flat, so I'd say the DOHC engine is just as useable as a SOHC.
The same argument was made about pushrod vs SOHC when Ford introduced the 4.6 in cars. It really doesn't matter how the engine is configured, you have to tune it and dress it out for the particular application and you'll get suitable results if you do it right.
2003 5.4s
Navigator DOHC 5.4 - 300hp@5000rpm, 355ft-lbs@2750rpm
F150/Expy SOHC 5.4 - 260hp@4500rpm, 350ft-lbs@2500rpm
For ease of maitenance and reliability would be a better argument to justify not using a DOHC in trucks. However, that's soon going to become a point not worth arguing over, as well.
-Kerry
Old May 30, 2006 | 09:32 PM
mat-helm's Avatar
mat-helm
Correct, thanks for going into more detail. But most people aren't going to retune their engine.
btw, are you sure about those spec's? I'm not up to date, but I thought the SOHC 4.6/5.4 made peak torque a little sooner than 2500. And I thought they peaked their HP a little sooner too.
Old May 30, 2006 | 10:25 PM
kspilkinton
Straight from fte's specs page - note that I used the 99-03 2V, not the 2004 3V specs.
I have the trucks' 2002 dyno sheet in my gallery... kinda hard to see, but those have been the 5.4 SOHC PI numbers since they were introduced in '99.
The torque curve is fairly flat... that's what makes the SOHC in the truck a good pulling engine. If Ford chose to use a DOHC, I'm very certain they could produce the same results. I think they went the 3V route to eventually go to a reduced displacement configuration. The variable valve timing lends itself to that application.
-Kerry
Old May 31, 2006 | 01:40 PM
DOHCmarauder's Avatar
DOHCmarauder
2003 5.4s
-Kerry
GREAT post!!!
If I may ad, Toy and Nissan use the DOHC 4V config. quite nicely in their rigs.
It's been beat to death here but I suppose if the product run lasts long enough, (sometimes doubtful with Ford) the 3V SOHC's one less cam and valve will prevail $$$$$ wise(even though the VVT adds cost and complexity to equal the 4V's #'s)........
I've just always felt the DOHC 4V was bought and paid for (been in production since the early '90's) and would have benefiitted more with devolopment (including VVT) than re-tooling for a TOTALLY new head.
Old Jun 3, 2006 | 10:41 PM
LxMan1's Avatar
LxMan1
I agree, the 4.6 DOHC in my sister-inlaws Mark VIII has 198,000 miles on it and still runs like a scaulded dog!! Plenty of torque since it has the dual intake runners with the flaps that shuts off 1 to each cylinder until about 3000rpm to keep intake volocity up.
Old Jun 4, 2006 | 02:15 AM
95-F250's Avatar
95-F250
I can't remember for sure, but seems I read a Continental 4.6 DOHC has different motor mount holes on the block, since they are FWD.
Old Jun 4, 2006 | 11:05 PM
LxMan1's Avatar
LxMan1
That is very possible, most of the other engines such as the 3.8 and 3.0 that are in front wheel drives have different block castings for the motor mounts.
Old Jun 26, 2006 | 03:26 AM
1948horse's Avatar
1948horse
There Is A Difference In Bellhousing Patterens. I Have 2 Aod-e Trans Basically Small Block Pattern But One Is A Different Pattern. These Are Out From Mid 90's Big Cars Like Merc Or Ford Rear Wheel Drive. The Different Pattern Sure Surprised Me. Lee
Old Jun 26, 2006 | 03:54 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome to the site 1948horse!!!!
outracn
Engine Swaps
Mar 16, 2026 06:25 PM
porchy's 69 f100
Dec 6, 2014 09:30 PM
Moto Mel
Jul 20, 2014 11:09 AM
Ford'05HG
Modular V10 (6.8l)
May 9, 2014 04:17 PM
kennethpitts2
Modular V8 (4.6L, 5.4L)
Aug 5, 2006 08:37 AM
