302 to 351
Old May 21, 2006 | 09:23 PM
logan1234's Avatar
logan1234
302 to 351
ok well i have a 88 f150 302 5spd...a guy just gave me a 351...its a carb. my truck is FI, first off, what all am i gonna have to do? can i use my 5spd 302 tranny on the 351?am i going to have to get a new wiring harness? and all that good stuff...?
Old May 21, 2006 | 10:16 PM
Kemicalburns's Avatar
Kemicalburns
do a search for this very topic. ive done this along with many others. you will need an efi upper/lower intake, tfi mounted distributor, oilpan & proper flywheel. the 302 wiring harness, throttlebody, motor mounts and accessory brackets should all fit onto the 5.8. you will also need to swap over the timing chain cover and the fuel rail/injectors as well. look on ebay for the upper/lower they are common. its worth it for sure and easy
Old May 22, 2006 | 07:21 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
Welcome to the site logan1234!!!
Kemical burns has about covered all the parts you need
Old May 22, 2006 | 09:59 AM
logan1234's Avatar
logan1234
no no no....im sorry i should have said it...im not going with EFI again...im going just carb... sorry guys.
how am i gonna go about doin the carb? caz i know im not going to need alot of the wiring harness now..so should i look for a new wiring harness..or just cut it out.. caz all i really need is gasline-brakes-and w/e other accessories i decide to have like a/c..
and what about the tranny...will my 5spd 302 tranny work on the 351?
and im planning on putting new gears in the rear end aswell... im thinkin 4.10
where can i find these gears at? or out of?
Old May 22, 2006 | 11:19 AM
Kemicalburns
why go backwards. efi is far better in a 4wd application and plus going carb wont pass emissions and is illegal.
Old May 22, 2006 | 06:35 PM
logan1234's Avatar
logan1234
well first off, its not a 4wd. its 2wd, and there is no emmision law in ohio any more, and i want the carb to run massive power...
Old May 22, 2006 | 08:02 PM
andym's Avatar
andym
Then you better get rid of that Mazda 5 speed.
Old May 22, 2006 | 09:37 PM
pfogle's Avatar
pfogle
Logan, the EFI system will give you better fuel economy and horsepower. And yes there are still emissions laws in ohio. If you go to carb from EFI it will not pass a visual roadside inspection.
Old May 22, 2006 | 09:40 PM
mikeyswood's Avatar
mikeyswood
Start doing your research. I built my 351 for EFI, and when I am done I am going to use my 302 for a EFI Mustang; perhaps a 65-THAT will walk the line!!
EFI is beter period.
Carb is easier period.
If you are willing to learn the EFI then it will make sense and become easier. Carb is popular for the same reasons guys drop 350s in 32 Fords--they're idiots......now that's not fair. Those systems are everywhere and they are understood by most people.
If you take time to learn the EFI, Comp and Crane can help you get the cam that meets your needs and you can build for all the power that you can handle.
The M5OD will work with a 351 but you have to be gentle. I believe that is was only rated for 200ish pounds of torque. It is real easy and pretty cheap to switch to a ZF.
The best thing you can do is keep asking questions.
Good luck and thank God the E Check is Gone!
Mike
Old May 22, 2006 | 10:53 PM
logan1234's Avatar
logan1234
ok well if i go EFI.... how am i gonna do that? will my 302 EFI system work with my 351? what about all the sensors and what not?
could u guys please just walk me through this entire process?
i mean i know cars and trucks pretty good so ill be able to keep up with ya guys...im just not sure on how to do this swap thats all... and i didnt think i could switch that carbed 351 over to EFI....i belive its an older engine to... soo. i dunna.. i would like to have the carb for the reason of having a nasty *** cam.. but if u guys say i can have a nasty *** cam with efi...then ill prolly go that route... i mean my intentions for this truck....is to have a mad tire layin machine...i was thinking about goin to an automatic C6 tranny but...i think it would be a bitch gettin it switched over to an auto... but if u guys are willing to walk me through everything...ill do whatever u guys say is best to do...
just start listing/telling me what i need to do... please....
can any of you give me some sites so i can start looking for parts?
Old May 22, 2006 | 11:48 PM
logan1234's Avatar
logan1234
ok another question...is my 5spd trannt gonna hold with this 351?
some say it will some say it wont...
how is the ZF tranny? and can i get a ZF tranny in a 5spd?
Old May 23, 2006 | 07:36 AM
mikeyswood's Avatar
mikeyswood
1) The Mazda (M5OD) will be fine for now. If you want truck power than you will want the ZF. If you want to spin the tires, then you want a Mustang. The ZF is a 5er with a 5.76ish 1st gear so it might spin the tires.
2) The best place for parts is eBay. The second best place for parts is the spring and fall Ford swap meet at the Columbus fair grounds (I haven't been yet, although I hear great things).
3) The intakes are the most improtant parts. An EFI upper and lower are the biggest part. There will be some other small stuff. Books like How To Build Small Block Fords and Ford Fuel Injection will help when doing the work and research.
4) Fordfuelinjection.com has some great info.
Mike
