Distributor trigger ?
Old May 21, 2006 | 05:29 PM
hschwartz3's Avatar
hschwartz3
I am trying to re-tune my stock Duraspark II distributor with some lighter springs and cannot get the trigger off the distributor shaft. Is there a trick/method to getting that little spring clip under the felt pad off?
Old May 21, 2006 | 05:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
The "trigger" or armature comes off with a small gear puller. Do not lose the roll pin that keeps it from rotating on the shaft.
The spring clip under the felt lubricant reservoir can be removed with some needle nose pliers if you are careful. Grasp one upright wire and "peel" it out of it's groove. The spring clip retains the "weight cam" or sleeve and plate assy onto the distributor shaft. There is a bronze bushing between the shaft and the sleeve that is lubricated by the felt pad.
Some specs if you need them:
1971 distributor & engine specifications for the 400
This was the GOOD year for the 400 engine before it was smogged to death.
Distributor part #D00F-U
Centrifugal Advance Start: 0-0.5° @ 350RPM Finish: 14° @ 2275RPM
Vacuum Advance Start: 0-1° @ 5" Finish: 12.5° @ 25"
Point Dwell: 26-31°
Initial Timing: 10° BTDC, 6°BTDC California.
Vacuum given in inches of Mercury (Hg).
RPM specified as distributor RPM.
Degrees specified as distributor degrees.
Double those values for crankshaft figures:
Example: 0-0.5° @ 350RPM distributor becomes 0-1° @ 700RPM on the engine.
Old May 21, 2006 | 07:21 PM
pcmenten's Avatar
pcmenten
Eric,
I cut-and-paste'd your entire response and saved it for future reference. Excellent information, as always.
Thanks.
Paul
Old May 21, 2006 | 08:09 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thanks!
I have a ton of info from here and other sources saved as a file. Sometimes I have been tempted to organize and edit it better and post it as a tech paper. I am not sure how legal it would be tho. I have attempted to preserve the sources but some of the info is edited for clarity or my own notes added etc.
utjer
May 5, 2010 02:12 PM
Old Brown Truck
Electrical Systems/Wiring
Jun 17, 2009 10:57 PM
hoxiii
Apr 4, 2006 05:28 PM
BigBrownTruck
Aug 10, 2004 11:16 AM
nevereverquit
Dec 29, 2003 06:59 PM
