Modular V10 (6.8l)
V10 head problems
Old May 20, 2006 | 07:06 PM
ROCKET DAD's Avatar
ROCKET DAD
V10 head problems
Hi everyone.my name is troy i have been a ford man my whole life (i am 42 )I recently traded in my 94 F350 for a 2001 F250 V10 4x4 I have owened the truck for @4 months and i am on the third spark plug that blew out of the head.does anyone know what FORD is going to do about this problem.I know lots of people with the same problem but not as extreme.any help would be appreciated.
Old May 20, 2006 | 07:35 PM
boxcar1974's Avatar
boxcar1974
Ford will do nothing to compensate you for the problem. Your best bet it to invest in timesert fix. It is a tough call, it not just the V10 with plug issues. All of the modular engines have had issues. The 4.6L, 5.4L, & the 6.8L. The most you can do is make sure all the plugs are torqued to the proper specs. It seems the 99-early 02's are the ones with the most problems. If I hade 3 plugs blow I would be driving something else. I don't know how you use your truck, but mine goes non-stop to the tune of 20K miles per year. I would hate the truck forever if I had that many plug problems.
Good Luck
Old May 20, 2006 | 08:30 PM
99f350sd's Avatar
99f350sd
Most likely someone did something wrong like didn't tighten the plugs or over torqued them. Use the timesert repair and take the rest out and check and torque.
Dick
Old May 21, 2006 | 08:16 AM
ROCKET DAD's Avatar
ROCKET DAD
I will check that out thanks
Old May 21, 2006 | 08:20 AM
ROCKET DAD's Avatar
ROCKET DAD
Question
I am unfamiliar with timesert repair could someone explain
Old May 21, 2006 | 08:32 AM
RBC-01's Avatar
RBC-01
here ya go.... www.timesert.com
good luck
Old May 21, 2006 | 08:36 AM
99f350sd's Avatar
99f350sd
http://www.timesert.com/html/triton_repair.html
Old May 21, 2006 | 11:22 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Moved to V10 forum - you'll get lots of answers here
And WELCOME to FTE!
Old May 21, 2006 | 03:13 PM
captchas's Avatar
captchas
Guest
http://fulltorque.com/ heres the other company that makes the good kits sounds like some one did not use the proper way of changing plugs .
imm its best to upgrade all at one time to the newer threads and be over with it forever
Old May 28, 2006 | 08:27 AM
ROCKET DAD's Avatar
ROCKET DAD
Thank you to all.
Old Jun 11, 2006 | 11:32 AM
ROCKET DAD's Avatar
ROCKET DAD
Talking got her back
well after 3 more weeks at FORD,I finally got her back.now I have 2 new heads and she is running great.ford picked up what the warranty didnt cover.(@$500)hope this is the end of this plug issue.
Pool Guy 23
Apr 23, 2014 10:51 AM
deputyb
Aug 22, 2011 07:28 PM
mhg
Modular V10 (6.8l)
Feb 2, 2008 08:02 PM
jhemr
Modular V10 (6.8l)
Jun 22, 2004 05:22 AM
mudcobra
17
Feb 3, 2004 09:38 PM
