Difference in carbs?
Old May 20, 2006 | 05:16 PM
pfogle's Avatar
pfogle
I recently swapped the carb on my 351w in my ltd with one off of a 302 f150. I'm wondering if there is a difference in CFM between the two as I now have a hesitation just off of idle.
Old May 20, 2006 | 09:22 PM
Ford_Six's Avatar
Ford_Six
There will probably be a difference in cfm, the 302 carb may be pretty small, depending on what year it's off of. What's the number cast into the side of the fuel bowl on the carbs? (something like 1.03, 1.21 etc.)
Old May 20, 2006 | 10:42 PM
pfogle's Avatar
pfogle
It's off of an 80 or 81 302. Not sure on the numbers, which side are they on?
Old May 21, 2006 | 01:34 PM
pfogle's Avatar
pfogle
Jared, I found two numbers on the carbs, 1.21 on both which is cast into the side of the bowl. The other numbers are a 7 on the new one which is a non cali emissions carb, and a 14 on the one that was in the car which has cali emissions. The 7 and the 14 are stamped into the top of the carb over the fuel bowl.
Old May 21, 2006 | 09:54 PM
Ford_Six's Avatar
Ford_Six
Ok, they are boththe same size carb. Try moving the accellerator pump rod up to the top hole on the actuator arm.
Old May 22, 2006 | 05:38 AM
pfogle's Avatar
pfogle
Got it fixed. Turns out the where we had the vacuum advance hooked to had no vacuum... I found another port where I had good ported vacuum now it runs like a top.
