94 f-150 fuel problem
Old May 22, 2006 | 10:20 PM
dons56's Avatar
dons56
cranks and cranks, won't start. has spark. no power at fuel pump. has power at relay. inertia switch ok. replaced relay with other known to be good. code reads 542. any ideas?
Old May 22, 2006 | 11:52 PM
LxMan1's Avatar
LxMan1
Sounds like a bad pump. Try smacking the tank with a 2x4 a couple of times. Sometimes this will jar the pump and make it start. If so, replace the pump.
