The Sending Unit For Autometer Gauges Replaces The Block Drain Plug At He Rear Drivers Side Of The Motor, Be Sure To Get The Right Threaded Adaptor For The Sending Unit , I Believe It Is Metric Threads , Autometer Can Give You The Right Part #'s Ordered Mine Today Should Be Here In A Few Days I'll Let You Know
running autometer phantom 2 awesome gauges electric you remove the block drain plug at the drivers side rear of the motor just below the freeze plugs and above the exaust manifold it takes a 6mm hex wrench i believe from summit racing part # atm2268 metric adaptor i would look into the phantom 2 gauges awesome wireing and match the stock gauges very well i put in ool pressure water temp trans temp and egt i hope that this helps
That helps ALOT! I have the Phantoms under dash but I think I want to run the 2 on the column. If I like it alot I will switch them all out for the 2's. Found all the parts on Summit.
Thanks for being the only other person to add a temp gauge! You are a pioneer!
yes it will it did me couldn't believe hot they run the fan did not come on until 220 deg good luck in putting the gauges in it is simple but if you run into any problems just let me know i will help if i can
