Intercoolers
Old May 20, 2006 | 01:11 AM
1997F-350's Avatar
1997F-350
Intercoolers
hey folks.
the ic bug has bitten. so i have been shopping. got a few questions.
for the superduty ic's i notice there are 2 kinds.
1 has plastic side tanks.
1 has aluminum side tanks.
which one is better? i assume all aluminum one.
is one more prone to have leaks or fail over the other?
then i see 6slow ics. these appear by the pictures to be much taller than the 7.3 ic. is this correct?
i wish gts would answer his email so i could see if he makes an obs pipe /mounting kit for 6 slow. or i guess i could borrow my dads welder.
thanks
Old May 20, 2006 | 07:33 AM
ltfox's Avatar
ltfox
I used the GTS kit to install a 6 oh cooler. The only thing you'll need is a 3 1/4 to 3" coupler/boot for the one sire of the IC. I bought mine from Ford. You can find them online alot cheapre though...I was in a hurry and did'nt want to wait for the mail. THe mounting hardware may have to be moded a little..depending on how the IC mounts. Iv'e seen a couple different ones. As far as plastic/aluminum....the latter is supposed to be less prone to fail...but I personaly have never heard of one failing that wasen't under extreme(60+psi) boost.
As far as the GTS issue. I wish ya good luck...I waited 2 months for my kit. MAybe a isolated instance...I dunno.
Good luck
Old May 20, 2006 | 08:14 AM
barebackjake's Avatar
barebackjake
i waited 2 months for my kit also for another truck recently. i wont do business with him again.
superduty pipes can be modded to work if you have acess to a welder and find a shop up there that can mandrel bend 3" then just get a EARLY 99 y pipe and clamp.
on the aluminum or plastic thing.....ive never seen either fail
Old May 20, 2006 | 08:16 AM
barebackjake
there was a guy over at the "other" site that had all the mod measurments on the SD pipes recently you could look through there to find them.
Old May 21, 2006 | 08:53 PM
lukecline's Avatar
lukecline
i say go with a 6oh cooler, its plenty of ic unless ya start pushing alot of boost. then you run the risk of popping the endtanks off. i ran mine for 30k miles and it worked great.
luke
Old May 21, 2006 | 09:18 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The change from aluminum to plastic tanks happened sometime in 01 I think. Couldn't guess why, don't know that one is any better than the other. The 6.0 cooler has about 20% more frontal area and also has plastic tanks. Seen a few post where the 6.0 guys can push 50+ psi through them without popping the tanks. Don't know for how long though.
Old May 21, 2006 | 09:51 PM
1997F-350's Avatar
1997F-350
i guess ill try to find a cheap 6oh intercooler. i dont plan on running anything that high in boost anytime soon/ever.
Old May 21, 2006 | 10:06 PM
barebackjake
i think the thing with the plastic tanks is there cheaper to mfg than aluminum and lighter wieght. i would put a 6.blow intercooler in mine but as soon as a larger turbo goes back in the tapercore is going back in.....
still tring to make the turbo decision......gtp38r? qssb h2e? ball buster? gtp37r? or the turbo bean has brewed up.....
hmmmmmmm
Old May 21, 2006 | 11:14 PM
1997F-350's Avatar
1997F-350
let me know what you decide and how much work and $$$ it is. i am contemplating a turbo in the near future also.
Old May 21, 2006 | 11:25 PM
barebackjake
the qssb h2e from wop is a complete bolt on kit, not a bad job to do. i had a hypermax h2e on the truck when i had some huge hybrids in it.
the ballbearing turbos require the superduty pedistal, uppipes, collector, ypipe, and plenums.
bean is supposed to have a bolt on that works with our pedistal and upipes im gonna call him tommorow.
i gotta get all this stuff done in the next 2 months
Old May 22, 2006 | 10:04 AM
barebackjake
decision made.
h2e and im gonna get the superduty setup with it and then i just have to buy the 3" plenums to go with it. the rest of the parts are included, down pipe, intake pipe, y pipe.......
Old May 22, 2006 | 09:16 PM
1997F-350's Avatar
1997F-350
i know a guy here in my town who has a quickspool on his obs...
lets just say you open the hood and all you see is one HUGE turbo. looks pretty cool. especially the 4 inch dp. i cant wait to see it go/dyno. looks like a fast truck.
Old May 24, 2006 | 06:11 AM
warpdriv's Avatar
warpdriv
If you go with the 6.0 IC and have a 4x2, you will need to lower your sway bar 3 to 4 inches depending on how you mount the IC. I did mine last weekend:
http://home.austin.rr.com/jkmr/ic02.jpg
http://home.austin.rr.com/jkmr/icfront.jpg
I am going to fab the pipes this weekend. After several attempts to contact GTS and no responses I am fab'n everything. It is a shame they are not more response becase they have a good product.
Best of luck.
Jeff Blumenthal
Austin, Tx
97 F350 CC SWD 4X2 4:10, Bully Dog 50hp chip, AFE Stage 2 Magnum Force, BD 4" Exhaust System, BD Exhaust Brake, BD AutoLoc, Overhauled tranny that has been revalved for tighter shifts, HD Torque Converter, EGT Shutdown Monitor, Air bag rear suspension assist, EGT/Boost/Tranny Piller Guages
Old May 24, 2006 | 05:24 PM
cookie88's Avatar
cookie88
FTE Emeritus
Hi Jeff. Welcome to Ford Truck Enthusiasts.
Old May 24, 2006 | 09:37 PM
warpdriv's Avatar
warpdriv
Thank you.
Just found this site lastnight. Looking forward to chat with some more of my diesel brothers.
