Intercoolers
Old May 24, 2006 | 10:09 PM
1997F-350's Avatar
1997F-350
i think i recognize the name. welcome to fte. your gonna like it here i think. its a much better place.
thanks for the help too.
Old May 25, 2006 | 11:39 PM
RubberDuck's Avatar
RubberDuck
Hey Jeff, It's me again. This is the site I call home. I frequent the other site too, just to get different views. I find that the guys on this site are alot more friendly. I'm not saying on the other site they aren't, but man they go at it over there. Anyway, over here, the site is alot easier IMHO to use if you are a supporter. It was the best $14 I spent in a long time. These guys taught me alot of what I know about my truck. Not to mention, you actually get an email when someone has posted to a thread that you have posted, or posted to. I find that annoying that you don't from the other site. Anyway, welcome to FTE.
Old May 28, 2006 | 07:47 PM
warpdriv's Avatar
warpdriv
Well got the IC pipes fab'd up and installed. Turned out to be easy. I say that because I found a parts store that sells mandrel bent exhaust tubes.
Here's a pic:
http://home.austin.rr.com/jkmr/icpipes.jpg
The passengers side took 3 90 degree pipe and the drivers took 2 90s and 1 45 degree pipes.
Initial drive'n around the corner was fun. Lost about 3psi boost. Cool down after some hot rod'n was faster. When I did a run from 0 to 75, it looked like she ran about 150 degrees cooler.
The real test with a full load. I will let y'all know.
If I had to do it over again, I would because I am a hopeless gearhead that can not leave anything alone. Y'all know what I mean.
Old May 28, 2006 | 07:49 PM
warpdriv's Avatar
warpdriv
Here's a pic:
Initial drive'n around the corner was fun. Lost about 3psi boost because of the volume of air in the IC being compressed. Cool down after some hot rod'n was faster. When I did a run from 0 to 75, it looked like she ran about 150 degrees cooler.
Old May 28, 2006 | 08:58 PM
RubberDuck's Avatar
RubberDuck
Jeff,
That looks awsome. Where did you get the tubing? I have access to stainless tubing, but it is pretty heavy stuff not like exhaust tubing. Very good job, well done.
Old May 28, 2006 | 09:43 PM
warpdriv's Avatar
warpdriv
I got them at Frank Auto Supply 458-9122.
jr2000sd
Aug 8, 2014 05:44 PM
Hank85713
Dec 29, 2013 06:51 AM
artieb
Nov 3, 2013 08:24 AM
timmyboy76
Jun 23, 2011 11:07 AM
jkidd_39
Aug 1, 2009 11:06 PM
