I used the GTS kit to install a 6 oh cooler. The only thing you'll need is a 3 1/4 to 3" coupler/boot for the one sire of the IC. I bought mine from Ford. You can find them online alot cheapre though...I was in a hurry and did'nt want to wait for the mail. THe mounting hardware may have to be moded a little..depending on how the IC mounts. Iv'e seen a couple different ones. As far as plastic/aluminum....the latter is supposed to be less prone to fail...but I personaly have never heard of one failing that wasen't under extreme(60+psi) boost.
As far as the GTS issue. I wish ya good luck...I waited 2 months for my kit. MAybe a isolated instance...I dunno.
Good luck
i waited 2 months for my kit also for another truck recently. i wont do business with him again.
superduty pipes can be modded to work if you have acess to a welder and find a shop up there that can mandrel bend 3" then just get a EARLY 99 y pipe and clamp.
on the aluminum or plastic thing.....ive never seen either fail
i say go with a 6oh cooler, its plenty of ic unless ya start pushing alot of boost. then you run the risk of popping the endtanks off. i ran mine for 30k miles and it worked great.
The change from aluminum to plastic tanks happened sometime in 01 I think. Couldn't guess why, don't know that one is any better than the other. The 6.0 cooler has about 20% more frontal area and also has plastic tanks. Seen a few post where the 6.0 guys can push 50+ psi through them without popping the tanks. Don't know for how long though.
i think the thing with the plastic tanks is there cheaper to mfg than aluminum and lighter wieght. i would put a 6.blow intercooler in mine but as soon as a larger turbo goes back in the tapercore is going back in.....
still tring to make the turbo decision......gtp38r? qssb h2e? ball buster? gtp37r? or the turbo bean has brewed up.....
h2e and im gonna get the superduty setup with it and then i just have to buy the 3" plenums to go with it. the rest of the parts are included, down pipe, intake pipe, y pipe.......
i know a guy here in my town who has a quickspool on his obs...
lets just say you open the hood and all you see is one HUGE turbo. looks pretty cool. especially the 4 inch dp. i cant wait to see it go/dyno. looks like a fast truck.
If you go with the 6.0 IC and have a 4x2, you will need to lower your sway bar 3 to 4 inches depending on how you mount the IC. I did mine last weekend:
I am going to fab the pipes this weekend. After several attempts to contact GTS and no responses I am fab'n everything. It is a shame they are not more response becase they have a good product.
Best of luck.
Jeff Blumenthal
Austin, Tx
97 F350 CC SWD 4X2 4:10, Bully Dog 50hp chip, AFE Stage 2 Magnum Force, BD 4" Exhaust System, BD Exhaust Brake, BD AutoLoc, Overhauled tranny that has been revalved for tighter shifts, HD Torque Converter, EGT Shutdown Monitor, Air bag rear suspension assist, EGT/Boost/Tranny Piller Guages
