What's the third terminal on the starter relay for?
'96 F250 7.3L PSD 4x4
I went out to start it the other morning, and got no response from the starter. Here's what I know:
Here's what I want to know:
Am I right about that third terminal on the relay? If so, I don't think buying a new relay will fix my problem. Since I get no voltage into that third terminal I'm assuming there's a short in the wire connected to it, and the relay never gets a signal to close the circuit to the starter.
I suppose I could just pay the $25 or so for a new relay & find out if that fixes the truck, but I live in the country & don't want to drive all the way to a parts supplier just to pay for something I'm not sure will fix my problem...
Any help would be really appreciated!
- The 'Wait to Start' light & all other lights came on & went off as expected, except the battery light, which stayed on
- The batteries are fully charged, and there is no corrosion on any of the posts.
- I heard all the normal clicks
- I can still start the truck if the key is in the ingition in the 'engine on' position and I short out (hotwire) the two main terminals on the starter relay
no, I didn't check the cable or the ignition yet...
it never occurred to me that the ignition switch might be the problem....I'll give that a try first. The cable into the relay is wrapped into other thick groups of wires...looks like a pain to expose it all the way back to the starter. I'll do it today though if the starter seems to be ok.
--thanks
--thanks
ok - the ignition switch is fine. The wire from the switch to the relay is also fine - there's no resistance between the switch and the relay. So, it must be the relay, plain and simple. The lowest setting my voltage tester has is 15 V (will pick up anything from about 5 to 15 volts), so I figure the signal sent from the ignition to the relay must be less than 5 volts and that's why I couldn't see it.
I'll post another reply once I get the new relay...
OK - bought & installed a new starter relay, and it didn't fix the problem. I'd turn the key to start it and still nothing.
So I knew it wasn't the relay, wasn't the starter (I could still hotwire it), wasn't the ignition switch or the lead from it to the relay. Frustrated I went back to my shop manual's engine wiring diagram to make sure I hadn't missed something.
Turns out I had missed something...the clutch position sensor switch. I looked at it and noticed that the switch assembly had slipped off a small retainer bracket. I put it back on, and bingo, problem solved.
Now the only problem is I have to drive all the way back to the parts supplier to return the relay!
TheKirbyMan
15
12-05-2010 11:26 PM
jeffgoll
10-28-2010 12:14 PM
wisconsin
1997-2006 Expedition & Navigator
02-03-2008 09:59 PM
