i have a 97 psd with a suncoast trans and conv. with about 4000 miles on it all of a sudden last week just driveing down the road at 80 my trans shifted out of od and into 3rd gear. after removeing my head from my dash i quickly hit the od button and and it went back into od went about 1 mile and did it again hit button and went back to od. so on and so forth no codes and every thing else works great just shifts all the time by it self now.please
If the only thing going wrong with your tranny is OD then the little wire going to the button may be shorting out. I am unsure how th check this but someone will jump in with othe ideas.
to check the wires for the OD button you need to pull the top of the clam shell off you steering column and you will be able to see if one of the very small wires have broken or almost broken. just soldier it back to gether and tape it up.
I have repaired several trucks for what tjbeggs has described. Most of em the wire broke. Easy enough to fix. And inexpensive. May want to check routing especially if you have tilt steering.
