rotating gear selector in AOD?
Old May 17, 2006 | 08:13 PM
Huntsman's Avatar
Huntsman
Question for the experts, I am attempting to add a Lokar Nostalgia floor shift to my 55 F100 running an AOD tranny from a 1989 F150. My selector lever on the tranny is pointing down and Lokar has advised me that the selector needs to be rotated 180 degrees or facing up. They said I would need to drop the pan and make the change.
I am comfortable with mechanical issues and have done considerable work on my old truck but fooling with a tranny will be new to me. Is this something that can be done fairly easily? Suggestions appreciated.
Old May 18, 2006 | 06:55 PM
rclarke's Avatar
rclarke
Drop the pan, loosen the nut on the inner end of the shift lever enough to move the internal lever off the flats on the shift lever. Rotate the lever far enough to reengage the inner lever onto the flats on the shift lever. Tighten the nut.
Old May 18, 2006 | 08:23 PM
Huntsman's Avatar
Huntsman
Thanks alot rclarke, I'll give it a try.
Old May 19, 2006 | 06:54 AM
stuart1's Avatar
stuart1
The valve body must be removed to gain access to the retaining nut.
There is also a pin in the case that must be removed.
gt40racing
Jun 9, 2012 09:42 PM
Woodsman_30350
Aug 18, 2008 05:01 PM
Huntsman
Jun 12, 2006 07:49 AM
tip49
Dec 14, 2005 08:50 PM
