1966 - 1977 Early Broncos
Disc brake conversions
Old May 17, 2006 | 01:02 PM
72 Bronco's Avatar
72 Bronco
Anyone recomend any Front disk brake conversions?
Old May 18, 2006 | 06:47 AM
hunter1897's Avatar
hunter1897
My recommendation for the front's is to read up and follow the directions for the Ford/Chevy conversion using Chevy truck calipers backing plates and spindles, then a Big Bronco hub/rotor assy. Worked great for me and save quite a bit of bucks by buying spindles and backing plates from the junk yard and competitive pricing on the other components.
Old May 19, 2006 | 01:33 AM
fordtrucksforever's Avatar
fordtrucksforever
Thats the best conversion for the bucks by far. Make sure you check some of the Bronco specific sites for detailed list of parts and mods needed to do it correctly. There is a broad range of year models for parts doners. There are a few different styles of Chevy calipers. Mainly the rotor width and location of brake line. A donor 4x4 chevy truck and even a Jeep Wagoneer will work. Bone yards should be full of these. I found most parts at one time from the pick-n-pull yards. The Ford rotor assemblies should still be under $35 from Autozone or O'Rileys. Go with new on these regardless. Get new pads, caliper kits and mounting hardware. New rubber brake lines from donor truck should work. Use a combination valve from just about any full size Ford truck with disks from 73 to mid 80's. I am going from memory on everything so be sure to double check before throwing the money down. I did the same conversion on my '67 halfcab with dana 30 front axle. This is a great time to get rid of the stock lines running from master cylinder. You can buy a double flaring tool that works very well from Harbor Freight. The brake line fittings are available so you dont need to use adapters. With some patience and studying some vehicles in the junk yard, you can make the conversion look like it was original equipment.
Old May 20, 2006 | 04:12 PM
Bobtailfan's Avatar
Bobtailfan
On my 70', I just picked up a 1978 front axle and changed everything over from the ball joints out. The only other component I needed was the bushings for the tie rod ends. The 78/79 carrier has a bigger tapered ID, so this allows you to use the stock 72 tei rod ends.
Good luck,
TK
Old Jun 5, 2006 | 07:26 PM
1964F250's Avatar
1964F250
Disc Brakes on 64 with straight axle
I have a straight axle on my 64 and want to go with disc brakes. I have the complete front end disc brakes from a 76 F-150 for the donor. Is there a kit to put these on the straight axle? I have new calipers and rotors for the 76.
Old Jun 5, 2006 | 10:37 PM
RCrawler's Avatar
RCrawler
If the front end on your 64 is original, it is a closed knuckle design. The knuckles will not interchange with the later model disc knuckles nor will the GM spindle out conversion work in your application. Your best bet to get disc brakes is to swap the entire front axle from a later model with disc.
Jason
Old Jun 5, 2006 | 10:41 PM
1964F250's Avatar
1964F250
Got any ideas what will work with minimal cost? I've spent way too much already getting in too big of a hurry. I thought I would have learned by now.
Old Jun 24, 2006 | 03:20 AM
fordtrucksforever
FInd a 1/2 oe 3/4 ton chevy or Ford truck with disks. Make sure the differential is offset to the correct side. 1/2 ton will need changed to light duty 3/4 ton rotors. You will probably have to weld on mounts to match your spring width. But this does make coil spring axles an option. I still see plenty of late 70's complete axle assemblies. The pick n pull yards are really cheap. Under $150 complete. If you are in a more rust prone part of the country, it may limit your chance of finding what you need for a fair price.
Old Jun 24, 2006 | 09:21 PM
RCrawler's Avatar
RCrawler
If it is a factory 4x4, should have a LH differential. Your best choice for disc brakes is a 76-79 Ford F150 or 250. Like FTF said, you may need to add spring pads. But it will be the cheapest option. The only problem I forsee is driveline angle from the high pinion front end. You could use a 94-02 Dodge front end, but they are a unit bearing hub design that is pretty expensive to replace. You would also loose the option of locking hubs.
HTH,
Jason
kodiak14
Dec 9, 2013 11:19 AM
LeRoy H
Mar 17, 2013 08:33 PM
Redneck135
1978 - 1996 Big Bronco
Jan 10, 2003 01:46 PM
OldFords
Mar 11, 2002 09:27 PM
duane
Nov 29, 1999 09:52 PM
