stealth small or large
Old May 16, 2006 | 11:46 PM
j.m. ray's Avatar
j.m. ray
on the d2oe-ab police head,does the larger port #8021 fit the port size better than the smaller#8012. this is the 2.19 intake valved head used in 73 and 74.i would rather grind on the intake instead of the heads.
Old May 17, 2006 | 09:22 PM
bbf150's Avatar
bbf150
i actually port matched my heads to the gasket,then i had to take some off the intake but not much-i used the #8012 stealth
Old May 18, 2006 | 01:56 AM
DeanG's Avatar
DeanG
I too am running the D2OE heads on my 460 and I used the 8012 manifold. With the compression and cam I am running, I left slightly smaller intake manifold ports alone. I am going for torque more than hp so my thoughts were that the step between the intake and the port in the head would help a little with blowback at lower rpm.
kilich
Nov 27, 2011 08:54 PM
Ranger92
May 17, 2011 07:30 PM
5.0stang
Oct 1, 2007 05:17 PM
jwrboss302
May 18, 2004 08:57 PM
ptrxly
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 15, 2004 02:07 AM
