v10 tune up thought this was easy!!
i tuned up my v10 this weekend and all plugs came out just fine. the problem was the #4 plug would not go back in. i ran a tap down through the hole and it went very easy. tried to install plug again and no go!! i even swapt plug from #1 cyl and it wouldnt go either. any help or suggestions thanks!!
Uh Oh!!!! You Ran A Tap In The Head? What About The Shavings? Were There Any? Did You Do It When The Engine Was Completely Cold I Hope? Anyway, A Hole Is A Hole... If You Ran A Tap And You Tried Another Plug In It And It Still Will Not Go In, I Never Heard Of That One, Sorry, Keep Us Posted Thanks.
if you ran the wrong tap in the cylinder, they sell taps and hellie coils(i can spell) at pepboy and autozone. basicly you tap out the hole bigger and put in the coil so that it returns to the right size.
If the engine is cold you should not have to worry about the cylinder. The first time you fire it up, all the little pieces fly out the exhaust port. Its usually a mechanics trying for more money on a rebuild.
I was under the same impression, when I had to tap a cross threaded plug in a vw corrado. I bought a rebuild kit, only to tear down the engine to find nothing wrong.
Chris
Good luck
Chris
Good luck
This kit here is exactly what you need. http://www.timesert.com/html/triton_repair.html
I haven't used it myself, but I've heard several people praise it.
heres the other good one guy just stay away from the auto parts store type they blow out also http://fulltorque.com both companys have great products
