Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
canopy lift system
Old May 16, 2006 | 11:24 AM
OLD COASTIE's Avatar
OLD COASTIE
Red face canopy lift system
Has anybody made a home system to lift your canopy by yourself up into the rafters of your shop. I'd appreciate any ideas, thanks.
Old May 16, 2006 | 10:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
Hello- Welcome to FTE! I have moved your post to the specialized forum we have here for your question. Check out the list of tech forums we have on FTE. There is a wealth of information and expertise here to help you. There are a number of links in my sig below to help you also. Have fun!
Rope and pulleys, not complicated at all. Just remember each pulley adds some friction.
Using 4 ropes wound on a common windlass is probably the simplest system with the least mechanical advantage (2:1). Using two ropes and more pulleys results in more complicated rigging to even out friction at each point but you can get a 4:1 mechanical advantage.
Old May 17, 2006 | 04:56 PM
frederic's Avatar
frederic
When I owned a full size bronco I built such a system... was four pulleys above the corners of the fiberglass top (on the ceiling, directly above), going to the luggage rack on the fiberglass top with hooks, and the ropes went from those hooks through the four pulleys to one wide pulley at the back of the garage and onto an electric winch. Push "up" and the fiberglass lifted off, push down, and it lowered.
The only thing that sucked about my "design" is the switches were "way over there" and aligning the bronco top while lowering it wasn't. Took a few walks back and forth. If you're smarter than me, you'll put the switches on the wall closer to the truck
Bowie
Sep 28, 2011 12:59 PM
series 3 guy
2004 - 2008 F150
Feb 6, 2011 09:45 AM
Visseroth
34
Feb 22, 2010 12:52 PM
fireguy1can
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Jan 13, 2009 03:03 PM
OLD COASTIE
Garage & Workshop
Aug 9, 2005 03:26 PM
