390 dwell
Old Apr 23, 2002 | 02:04 PM
atkman's Avatar
atkman
390 dwell
Does anybody know what the dwell on a 68 ford 390 should be? I've been told to just set the points to 17 thou, but I want it in deg dwell.
Thanks.
Old Apr 23, 2002 | 03:41 PM
BB's Avatar
BB
390 dwell
26* - 31* if the memory is still working.
Old Apr 23, 2002 | 10:29 PM
IronSled's Avatar
IronSled
390 dwell
31 sounds about right to me
Old Apr 24, 2002 | 07:58 AM
evans's Avatar
evans
390 dwell
28-32. Closer to 28 is best.
Mike
Old Apr 24, 2002 | 09:58 AM
buzzard's Avatar
buzzard
390 dwell
Actually:
Curb Idle 550 Dwell 26*-29*
Cold Idle 1400 Point Gap 0.017"
Plug Gap 0.032-0.036"
Initial Timing
w/o exh. Emissions 10* BTC
Old Apr 24, 2002 | 10:15 PM
BB's Avatar
BB
390 dwell
Hmmm... I just looked this up in the '68 truck shop manual. If you have the single-diaphragm vacuum advance your point gap is .017" and the dwell is 26-31 degrees. If you have the dual-diaphragm vacuum advance the point gap is .021" and the dwell is 24-29 degrees. Says the same thing in the '68 truck service specifications booklet.
Barry
Old Apr 26, 2002 | 09:17 AM
buzzard's Avatar
buzzard
390 dwell
[updated:LAST EDITED ON 26-Apr-02 AT 10:19 AM (EST)]According to my genuine Ford Motor Company publications, all 1968 Ford truck engines, save for heavy duty models which the 390 is not classified, were equipped with exhaust emission equipment, whether it was the Imco or the Thermactor. Again, per Ford Motor Company's official publications, the dwell angle for 360's and 390's is between 24º and 29º. Hope this clears up the issue.
Old Apr 26, 2002 | 10:15 AM
BB's Avatar
BB
390 dwell
Hi Jim,
Not trying to be difficult or anything but my data is also from the genuine original ’68 Ford truck shop manual and the original ’68 Ford truck service specifications booklet, all from Ford. I was a service tech at a Lincoln-Mercury dealer in the early ‘70’s in the quick service and electrical department and went through all the dealer training on this for tune-ups, still have the training books with the slide presentations (makes for exciting slide shows at home!). They explained the differences between IMCO and Thermactor along with the single/dual vacuum advance units. It all has to with the geometry of the movable breaker plate vs. the breaker cam. The pivot point of the breaker plate is not concentric with the cam so instead of rotating around it, it really swings an arc across it. This changes the dwell angle as the breaker plate moves. It wasn’t so much a “problem” with the single advance but with the introduction of the dual advance they had to increase the point gap so that when the plate moves forward on retard the point gap doesn’t get too small. It was never really meant to go in this direction. That’s why the two different gap settings. It’s a cheesy design, that’s why I remember .017” = 26*-31* and .021” = 24*-29*. Anyway, don’t want to “dwell” on this to long, in this day and age of electronic ignition it seems “pointless”.
Barry
Old Apr 28, 2002 | 03:17 PM
dinosaurfan's Avatar
dinosaurfan
390 dwell
Atkman, Barry is right, this is not something we should be dwelling on. It shouldn't even be discussed, throw away those points and get a duraspark or a pertronics. Points are really nowhere.....it IS 2002. DF
Old Apr 28, 2002 | 03:48 PM
Ratsmoker's Avatar
Ratsmoker
390 dwell
JRB64
Jul 23, 2017 08:42 AM
mrpotatohead
13
Feb 27, 2017 11:43 AM
ddlyarmbar
Jan 6, 2007 11:46 AM
doubletree
Dec 2, 2004 08:10 AM
cole_boy
Garage & Workshop
Jan 29, 2003 07:45 PM
