Speedo Gear Swap
Old May 14, 2006 | 07:50 AM
Tom.Lapham's Avatar
Tom.Lapham
Speedo Gear Swap
I swapped gears in the rear from 2.73's to 3.55's, now the speedometer reads high ...(44mph reading = 35 mph actual).
The speedometer gear in the tranny (5 spd manual) has 17 teeth.
How many teeth should I go to to get close?
Old May 14, 2006 | 03:12 PM
53fatfndr's Avatar
53fatfndr
I went through this last summer. If memory serves, I believe the general rule of thumb was one tooth for every 5 mph change. However, the speedo will still be off a little but it will be closer. Good luck.
Old May 14, 2006 | 10:26 PM
F150xlt's Avatar
F150xlt
First go to http://www.tirerack.com
Pick the size of the tire you have. Then look at the chart for
how many revolutions per mile.
Then go to http://www.fordracingparts.com/download/charts/142.pdf
Insert the numbers in the formula to calculate the number of teeth for the driven gear.
Note manual trans. and older 4x4's which have the speedometer driven gear in the transfer case use the same driven gear.
Auto trans. driven gears are different.
filthy6
Nov 6, 2016 05:08 PM
David8949
Jul 21, 2016 10:41 AM
Josh S
1983 - 2012 Ranger & B-Series
Nov 21, 2015 04:58 PM
forkandbowl
Aug 7, 2015 07:09 AM
brokeasajoke
13
Aug 12, 2014 04:55 PM
