oscillating idle
Old May 14, 2006 | 07:37 AM
Ranger88Den's Avatar
Ranger88Den
Question oscillating idle
I have a 1988 Ranger, 2.9, auto. with an oscillating or rolling idle that ranges up and down about 100 rpm. No DTCs are displayed. Has anyone had a previous experience like this and/or a solution? All suggestions are welcome. Thanks
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old May 14, 2006 | 10:20 AM
pawpaw's Avatar
pawpaw
Dan, did this come about slowly over time, or suddenly after some event?????
Old May 14, 2006 | 10:56 AM
Ranger88Den
Just purchased the vehicle so I am unsure. Thanks for your response.
Old May 14, 2006 | 12:23 PM
RangerPilot's Avatar
RangerPilot
Is there an idle air control valve on the 2.9L?
Little metallic cylinder on the side of the throttle body on most of the later engines, including the 4.0L, which is a derivant of the 2.9L in many aspects.
RP
Zach
Old May 14, 2006 | 12:45 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Carbed or EFI?
Old May 14, 2006 | 01:14 PM
pawpaw's Avatar
pawpaw
OK Dan, well we'll need some more detail & hints to try & zero in on this one.
On idle problems, a long typical list of things to investigate are, throttle body or carb, fastner tightness & gasket/s condition, vacuum leak/s, vacuum hose connections & vacuum hose condition, pluged PCV valve or hose, clogged air filter, fuel pressure, leaking head, or intake manafold gasket, secondary ignition system problems, like worn plugs, with spark gap erosion, or dirty internal/external insulators, leaky spark wires, maybe even cracked insulstion/leaky coil or coilpack, worn camshaft lobes.
So maybe a visual check out of the vacuum hoses, then monitor the intake side with a vacuum gauge, a fuel pressure check & a compression check, would help narrow things down some.
Let us know what you find.
Old May 15, 2006 | 05:38 AM
Ranger88Den
Sorry for the delay but only have computer access occasionally. It is fuel injected w/IAC. I am in the process of a tune up as we speak. I will check the intake system bolts for tightness and vacuum lines for leaks. Thanks for your response.
Old May 15, 2006 | 07:10 AM
RangerPilot
Pull and clean the IAC while you're in there. As I said, it's known get dirty then cause the idle to oscillate, idle too low, idle too fast, etc. After the tune up, start things up, sometimes you'll fix it without knowing it.
RP
Zach
Old May 15, 2006 | 11:35 AM
Ranger88Den
Thanks everyone.
Old May 15, 2006 | 04:28 PM
RangerPilot
Did you get it fixed?
RP
Zach
Old May 16, 2006 | 12:34 PM
Ranger88Den
Not yet. I'm kinda slow. I have removed, cleaned and checked the operation of the IAC just not installed yet. Glad it's not my daily driver. Thanks again.
Old May 16, 2006 | 02:56 PM
Bob Ayers's Avatar
Bob Ayers
One other suggestion, measure the voltage on the signal wire from the TPS (Throttle Position Sensor). The voltage should be between 800mV - 900mV.
Old May 17, 2006 | 01:26 AM
john72ss's Avatar
john72ss
maybe others can correct me here, but i have the same year ranger and engine and i bought it brand new and it always had a rough idle of maybe 50 to 100 rpm! when i test drove it and noticed it the salesmen said oh they all do that! i said right so lets check a few more out!!! and every single one i drove did the same thing! so after 300,000 miles i guess it wasnt much of a problem! hope this helps!
Old May 17, 2006 | 07:25 AM
RangerPilot
john72ss, I don't mean to challenge you on that, but I've never seen or driven in a vehicle which didn't idle at a steady constant number (assuming A/C off).
RP
Zach
