EDGE ?'s
Old May 12, 2006 | 07:18 PM
yellow98cobra's Avatar
yellow98cobra
EDGE ?'s
Do I have to return the Truck to Stock to change performance levels?
Do I have to input the Tire and gear sizes on the stock performance levels?
Old May 12, 2006 | 09:11 PM
RDavis - OKlahoma's Avatar
RDavis - OKlahoma
I haven't had any trouble changing to different performance levels as long as I didn't customize any settings.
Also, I have not had any trouble re-tuning while on the same performance level such as Level 2 tuning and changing the timing, gear ratio, tire size, shift firmness, etc. multiple times to find what I liked.
I did get an error, however, when I changed to Level 3 tuning and tried to load "previous settings" that I used on Level 2. When this happened, I decided to just re-installed the edge software, selected the level 3 tune and customized the parameters I wanted.
Short answer to your question - I don't think you have to return to stock to change performance levels but I wouldn't try to load "previous settings". Also, I would change the gear ratio and tire size if they don't match your setup.
Old May 12, 2006 | 09:34 PM
WhëëlMå1's Avatar
WhëëlMå1
No, you shouldnt have to go back to stock. The only time you need to return the truck to stock, is when you update the tuners program online. The tuner should pick up your tire size and gearing...but you might want to *check* it, to make sure it did it correctly.
backtrailboy2332
2004 - 2008 F150
Oct 4, 2010 06:02 PM
PaysonPSD
39
Feb 1, 2008 11:34 PM
FTE Ken
Site Announcements
Nov 24, 2006 11:25 AM
RDavis - OKlahoma
2004 - 2008 F150
Aug 4, 2006 10:24 AM
fvm705
Modular V10 (6.8l)
Mar 15, 2004 07:34 AM
