Violent Vibration
Old May 12, 2006 | 09:17 AM
EDSELL's Avatar
EDSELL
Question Violent Vibration
2004 F-150 4x4 4.6l Wide Side/i Need Your Help This Does Not Happen Around Town Drive,on The Hi Way Around 60mph Steering Wheel Foward Hood Fenders Front Tires In O/d..violent Up Down Vibra.pull Off To Side Of Rd.go Into Park Wait2-3min Back On Hiwayd Does Not Happen. This Cant Be The Only 2004 Thats Doing This Please Help Thanks Edsell
Old May 13, 2006 | 06:42 AM
WhëëlMå1's Avatar
WhëëlMå1
Sounds like your emergency brake is sticking. If you do a search for that, you should find all the info on what is causing it, and how its fixed.
Old May 14, 2006 | 06:25 AM
tankblake's Avatar
tankblake
Your e-brake cams are not releasing, causing the rear drum to heat up the long you drive it! fixed a lot of them for this virbration concern! like wheelMA1 said
60F100
16
Jun 20, 2014 07:17 PM
classic ford guy
16
Jan 21, 2012 05:40 PM
EDSELL
2004 - 2008 F150
Jun 9, 2006 03:46 PM
EDSELL
New Hampshire Chapter
Feb 15, 2006 12:58 PM
kts_fordman1
Nov 15, 2002 05:01 AM
