Turn signal problem
Old May 11, 2002 | 04:31 PM
bigoldblue's Avatar
bigoldblue
Turn signal problem
Hey all,
I've got a turn signal/brake light not working. pretty sure it's the switch. if the turn signal arm isn't in a perfect spot my brake lights don't work. My question is--is there anyway to wire either the brake lights seperately so they don't run through the turn signal switch, or run the turn signals through a toggle switch on the dash, or will that overload the rear lights? also, I know i should just replace the turn signal switch, but no money to buy a new one.
thanks everybody
david
Old May 11, 2002 | 07:45 PM
bigoldblue's Avatar
bigoldblue
Turn signal problem
forgot to include this is a 1971 f100 4x4
Old May 11, 2002 | 09:26 PM
oleblue70's Avatar
oleblue70
Turn signal problem
First off,you will have to go to a yard to hopefully find a good one.There is no new signal switch for '67-72's.Second they are a bear to put in.Also they make a tool to push the terminals out of the plug.
Now,For a bypass on the brake lights,Just take one side of the two wires going into brake switch and get a fuse tap,plug that wire you choose into a key off fuse.There's some brake lights for ya.
Now try this(worked many a time for me)Take steering wheel off,take a fat punch that is fat and flat,no bigger that the rivit holding the turn signal cam to switch and "peen" it severel times.Then check your light,no go then hit harder!If any of you think i am crazy,I have gotten 5 years from a "bad" switch by making the rivet tighter so the contacts meet.That is ussually the problem anyway.Just good ol fashion wear.I have done this to three trucks and in my young life none of them ever screwed up again~
Old May 11, 2002 | 11:54 PM
oleblue70's Avatar
oleblue70
Turn signal problem
EDIT ,myself.The wire(both red)that come out of the taped up fat band of wires,the one from fuse box,that is the one you want to tap into the the fuse box to make your own power.The other one goes to the TS switch.
Old May 12, 2002 | 01:42 AM
bigoldblue's Avatar
bigoldblue
Turn signal problem
If i just run a hot wire to the brake lights what will happen to the brake lights when i use the turnsignal? will i have one brakelight and one turn or just brake lights?
thanks
david
Old May 12, 2002 | 11:11 AM
oleblue70's Avatar
oleblue70
Turn signal problem
The brake light and turn signal are on the same element in the bulb.The other element is the taillights.As for keeping the signal if you tapped the brake power somewhere else,I cant remember if they will still work.I got wasted last night so i cant really think right now.
Old May 12, 2002 | 12:08 PM
fordmando's Avatar
fordmando
Turn signal problem
[updated:LAST EDITED ON 12-May-02 AT 01:09 PM (EST)]There is no way I can think of to have both the brakes and turn signals work without either complex wiring or a working turn switch.
You might want to read the technical article I wrote on this web site, it explains in great detail the workings of the turn signal switch on your model truck (I did the repair on a 70 F-100.)
It is a bit time consuming to replace the switch, but not impossible, and yes, you can buy a new one. I got mine from Dennis Carpenter, it may be available on this web site as well.
fordmando
70 F-100 460 C6
78 F-150 4x4 400 NP435
George Selby
Old May 12, 2002 | 05:17 PM
oleblue70's Avatar
oleblue70
Turn signal problem
A new one huh?Man,I looked all over and all i found was the thing that makes your signal cancel when you turn the wheel.
My riggin' works so good enough for me.
Old May 12, 2002 | 05:32 PM
bigoldblue's Avatar
bigoldblue
Turn signal problem
well, your little trick about smacking the rivet w/a hammer works great. I now have brakelights and turnsignals again. thanks for the help
david
Old May 12, 2002 | 08:06 PM
oleblue70's Avatar
oleblue70
Turn signal problem
Your welcome.It is not a permanent fix on any given truck i suppose,but me for never had another problem.I alrealy plan on my current(rivet smacked truck)if it quits again,I'll just get a bigger hammerThis truck has along time on that trick!https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=2973&.jpg
For you "correct" guys,I have three or four columns with maybe?good switches,but those are a reserve
Old May 13, 2002 | 10:23 AM
karlsd's Avatar
karlsd
Turn signal problem
Jason, that's awesome. Great tip. It's exactly that kind of wisdom that makes this board great.
When I bought my '69, the turn signals didn't work and I traced it to the switch. I spent $50 on a NOS switch and several hours swapping it in. I wish I'd had your tip then.
Old May 13, 2002 | 07:12 PM
oleblue70's Avatar
oleblue70
Turn signal problem
Thanks Karl.I credit this board,friends,family,experience for all i know,but when you come up with a trick that actually works yourself,makes ya feel good.I came up that idea when i was 18,9 years ago and still learnin'!Does it ever stop?
Old May 13, 2002 | 08:26 PM
Tractor Will's Avatar
Tractor Will
Turn signal problem
Old Jun 19, 2005 | 10:14 PM
gdawghereiam's Avatar
gdawghereiam
i just got a turnsignal switch (70250) from mac's antique auto parts inlockport,ny.it was about $80.
gdawg7025082350
Old Nov 23, 2005 | 10:19 PM
gdawghereiam
Thumbs up turn signal switch
i didnt need the switch (spare) i just took apart the union that the turnsignal switch wires plug into.i cleaned the little studs with a pocketknife and put it back together and all the rear lights worked.
