Rhino Liner
Old May 10, 2006 | 07:35 PM
79 FORD's Avatar
79 FORD
Rhino Liner
Does any one know roughly how much it cost to spray this stuff on? Im wanting to do my bumpers and the bottom of my cab with it.
Old May 11, 2006 | 04:50 PM
tmyers's Avatar
tmyers
If I remember correctly to do the bed of my truck it cost about $600.
Old May 11, 2006 | 10:49 PM
dono's Avatar
dono
Gone but not forgotten.
It is not as tough as spray-on bed liner, but you can buy spray cans of undercoat that might work well for what you want to do ...... and they're cheap.
Dono
Old May 11, 2006 | 10:55 PM
G'sRed99F150's Avatar
G'sRed99F150
$400 for my Line X. Going to do my boat trailer this spring.for about $150. I don't know much about the cans, but if it's for undercoating, it will probably be worth it.But do the bed with a spray-in, you can't go wrong. Do all the prep work yourself to save some cash.
Old May 12, 2006 | 09:03 PM
79 FORD's Avatar
79 FORD
what is there for prep work?
Old May 12, 2006 | 09:07 PM
G'sRed99F150
The removal of any rust.Alot of these places that spray them charge quite a bit for rust repair, and wont warranty them.
Old May 12, 2006 | 09:56 PM
captchas's Avatar
captchas
Guest
about 600 for my 05 .and they did all the sanding and prep work 1/4 inch thick all around . no problems at all .no over spray. they just did a great job and it took about 5 hours total time. i saw 3 guys sanding the paint for preprep and then 2 washed it down with acitone solvent and 1 sparyed it.
for bumpers and body you may want to talk to a body paint supply shop as there are paint products out for that purpose just they are clear and look better then bed liner looks like orange peel in the paint when dry
Old May 13, 2006 | 02:38 AM
billybob_81067's Avatar
billybob_81067
There's a product on e-bay that you can buy and do it yourself. It's a 2 part epoxy bedliner called Rattleguard. I just sprayed the interior of my cab on my 95 Powerstroke with that stuff and it's awesome! Kinda the pits to mix, and don't plan on your hands being clean for awhile afterwards! LOL
here's a LINK
Old May 23, 2006 | 05:51 PM
TP83's Avatar
TP83
i know its old, but i want to do the bed in my truck and i have this lining called hippo coat. What is the process of painting the bed do i need to do all that sanding or what?
Old May 25, 2006 | 02:03 AM
hobo.labo's Avatar
hobo.labo
Sanding in ?
"A house is only as good as its foundation".
Rust for a foundation no thanks, why not do it right the first time.
Have it sand blasted, it's not that expensive, or maybe buy your own equipment and do it yourself. Again not that expensive unless you don't have a compressor. About a 2 hp is all you really need for a small job.
Just takes a little longer.
Hobo
