high volume oil pump
Old May 12, 2002 | 10:08 AM
bikerwolfie's Avatar
bikerwolfie
since i know what my problem is with low oil pressure ( worn mains). can i use a high volume oil pump to help increase the oil pressure? other than the mains the engine is in good shape doesn't knock, or smoke, compresson is good. just trying to extend the life a little longer. thanks for the advise.
Old May 12, 2002 | 11:48 AM
Mil1ion's Avatar
Mil1ion
[updated:LAST EDITED ON 12-May-02 AT 12:52 PM (EST)]I was looking through a web site about cams and they WARN Against using a high volume or High pressure oil pump in street applications.
I'll look for it an post it here.
EDIT
http://www.cranecams.com/master/stdrvgear.htm
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Old May 12, 2002 | 11:57 AM
royf250's Avatar
royf250
It's probably a good idea. However somebody once told me the problem with high volume is the fact that the valve covers can get filled with oil from the sump and leaving it critically low in oil. The problem: the oil will follow the path of least resistance and thats through the valve train and the oil passage returns from the heads are too small. The solution is to place an oil restrictor to each of the oil supplies to each head. This is a drop in washer like device that goes under under the rocker arm support pedestal that supplies oil to each head. That decreases the hole oil diameter, thus decreasing flow....at least in theory. Not really too sure where to get these or if they are a homemade item. Good luck
Old May 12, 2002 | 10:21 PM
dinosaurfan's Avatar
dinosaurfan
KurtWolf, what engine are we talking about here ? A high volume pump MIGHT help your pressure situation, but it would help us if we had some more information........DF
Old May 14, 2002 | 03:39 AM
bikerwolfie
it's a 360. my parts guy is going to order a couple of different sized main bearings i'm going to replace the mains, he said they make a high volume and a high pressure pump, different pumps from what he says. so i'm thinking of putting in a high pressure pump when i do the mains, any thoughts?
Old May 14, 2002 | 03:51 AM
Ratsmoker's Avatar
Ratsmoker
You need to have the oiling system modified. Drill the passage from the oil filter adapter to the oil pump out to 7/16" and use a high volume oil pump. Some people choose to use oil restrictors under the rocker shaft stand to prevent filling of the valve covers. Also fill the pan to 6 quarts instead of 5. This will not leave the crank spinning in oil so don't worry.
Old May 14, 2002 | 07:17 AM
TomThrall's Avatar
TomThrall
Some of the bearing manufacturers make undersized bearings. Since you are considering removing your oil pan anyway to install the pump, have you thought about putting new bearings in the rods and mains?
You would not have to pull the crank to do it.
tt
Old May 14, 2002 | 11:17 AM
bikerwolfie
my parts man is going to order std. and .001 oversized bearings. i'm going to put which everone fits the best in when i drop the pan again.
never put mains in from underneath, is there anything to it?
Old May 14, 2002 | 05:04 PM
dinosaurfan
KurtWolf, tell your parts guy to hold off awhile. You may not need new mains. If they aren't spun and they are quiet, leave them alone. Even if you have .003-.0045 clearance, they'll be okay. How much pressure do you have at idle ? If you are going to remove the pan, by all means put a bigger pump in it. A mellings M57HV is the one you need. A better pump drive would be cheap insurance against problems. And replacing a pump and drive is a whole lot easier than doing the mains with the crank in. It isn't that you can't do it, but it may be a whole lot more work than you really need. The FE series has a few issues that could be addressed that would help you a bunch more than new mains would. How about jumping over to the FE section and we'll talk about it. DF
Old May 15, 2002 | 04:13 AM
whitebenz's Avatar
whitebenz
Post high volume oil pump
blisstruck
Mar 21, 2012 02:37 PM
smolicht
May 9, 2008 08:14 AM
ford390gashog
15
Jan 25, 2006 01:02 PM
ford390gashog
21
May 13, 2005 09:47 PM
lastchance
Jun 7, 2001 06:35 PM
