Transmission Advice
Old May 10, 2006 | 01:58 PM
Riata_Ag's Avatar
Riata_Ag
Transmission Advice
Will some of you offer some advice as to the following questions that I have about automatic transmissions:
The truck is a '97 F350 4:10 LS Auto w/ overdrive
1. Can you reccommend an after-market tranny cooler
2. Trans temp guages? Brand / Supplier
3. What is the ideal temperature for these trannys to run under load to prevent pre-mature wear? In other words what is the temp threshold to try and stay under?
Thanks in advance for your time and efforts with my Ford education.
Old May 10, 2006 | 02:33 PM
Gene W's Avatar
Gene W
Riata-AG,
Tru Cool or Hayden make good aftermarket coolers and I believe Hayden makes the factory external coolers that come with the towing package option. Looking at how your truck is equipted, I would guess that you have the factory external as well as the standard internal in the radiator. If you aren't towing real heavy, that combination should be adiquite. On a '97 (high miles), you may want to flush out the cooler / coolers though.
Tru Cool is offering a model without the cooler by pass valve for your truck because the trans has one already. Do a search on Tru Cool.
I like Auto Meter gauges. Check our site sponsers or searce the web for many suppliers. There are others available from VDO etc. Here is a link to a picture of where the sender goes in the transmission.
http://community.webshots.com/photo/...43762250ViGceG
Around 160 is normal operating temp.
Gene
Old May 11, 2006 | 06:58 PM
trike1946's Avatar
trike1946
I'll second what Gene said. Check our sponsors for parts. Good luck with it.
Old May 12, 2006 | 12:19 PM
BEECHBM69's Avatar
BEECHBM69
I have a Tru Cool 4590 and it works extremely well. I removed the stock external cooler and run the Tru Cool in its place.
I also have Autometer gauges and mine rarely goes over 150* light, and I've never seen over 180* under any conditions. I've read where anything approaching/over 220* is dangerous to the health and well being of the trans.
Hope this helps.
Dan
jstihl
15
Sep 10, 2016 05:15 PM
My-Hobbies
Nov 2, 2015 12:09 AM
CanadianSmokie
Jun 26, 2009 06:49 AM
tbart16
Apr 19, 2007 03:22 PM
Racer944
Jul 27, 2004 02:32 PM
