Cold start-up engine light blinks
Old May 9, 2006 | 04:02 PM
mjfitting's Avatar
mjfitting
It only happens when I crank up in the morning. The engine reves a little higher than usual, the check engine light blinks 3 times and when it finally idles down it almost konks out. After this the truck runs fine. Any ideas, I tried a code tester and nothing came up as wrong. I think may be O2 sensor or maybe EGR valve. 95 F-150 302
Old May 10, 2006 | 04:08 PM
mjfitting's Avatar
mjfitting
Went to Auto parts store ran another scan, he didn't find one but the engine light blinked a 33 code. EGR valve not opening. I have read that it might not be the valve itself but could be the EVP or EVR sensor and I am not sure if I have a PFE sensor on this year truck.
Old May 10, 2006 | 09:18 PM
handyman43358's Avatar
handyman43358
Best way to tell is to try to manually open the EGR itself with a small screwdriver prying back the diaphragm through the little holes. Or better yet, carefully pull the two connected vaccuum lines off the EVR (EGR Vaccuum Regulator), which on a V8 is near the coil on the drivers side. Run a small hose into either side of the vaccuum lines (connect them) and the EGR should open, and if it's idling, it will probably die, or sputter severly. If nothing happens, bank on your EGR being rusted shut.
If you manually connect the lines at the EVR, and it does sputter out, then check the connection to the EVR. If all looks well, plan on the EVR being toast.
BriR
18
Apr 16, 2021 09:08 PM
chiefsfootball
Jan 8, 2015 03:13 PM
98infinity
1997 - 2003 F150
Jul 24, 2007 08:38 AM
gramps2plus1
1997 - 2003 F150
Mar 22, 2007 02:06 AM
walkerrim
Electrical Systems/Wiring
Jun 1, 2005 09:55 PM
