blinking alternator light
Old May 30, 2005 | 02:01 AM
walkerrim's Avatar
walkerrim
I have a 78 f-150 400ci that the alternator light blinks but when I turn on the lights the blinking stops. Any ideas as to why? Thanks
Old May 30, 2005 | 10:16 PM
Franklin2's Avatar
Franklin2
Does it blink only when you rev the engine, or only when it idles? Is it a regular blink or sort of random?
Old May 30, 2005 | 11:25 PM
walkerrim's Avatar
walkerrim
it blinks brighter at higher rpm's sometimes it will go all day and not blink but when it starts to blink it usually does it for quite sometime
Old May 31, 2005 | 10:32 PM
Franklin2's Avatar
Franklin2
I would unplug and clean all the connections out at the alternator and the regulator. Just messing around out there may fix it. Make sure you disconnect the battery before you start.
Old Jun 1, 2005 | 12:19 AM
Holmesuser01's Avatar
Holmesuser01
Any chance that this is the original alternator? Could need new brushes! I got 300K out of the original alternator on my 84 f-150
Old Jun 1, 2005 | 12:23 AM
walkerrim's Avatar
walkerrim
not sure if its the orig or not. Why would the blinking stop if I turn the lights on. Seems to me that is just the opposite of what should happen.
Old Jun 1, 2005 | 09:55 PM
Dealford's Avatar
Dealford
Are there any signs that the battery has been getting over charged? Is there a smell of rotten eggs near the battery?
Maybe, just maybe, the voltage regulator is on it's way out.
The next time the light is blinking, check the voltage at the battery to see if it's high. Check it at idle & reved up & then with the headlights on to see what you're getting.
AL.
bert cook
Feb 13, 2026 05:21 PM
lylino
Escape & Escape Hybrid
21
Aug 3, 2017 04:10 PM
Fastfwd
Aug 22, 2013 10:02 AM
Branny08
Apr 2, 2012 07:02 PM
WiNgRg
Mar 28, 2010 11:48 AM
