replacing bed, suggestions?
Old May 9, 2006 | 12:22 PM
low54's Avatar
low54
Fella's
The more I start body work on my 54 the more I want to do it right. The current bed Is in stright condition however, has many dings and pits. There's minor rust. Even if I blasted the bed and did some bondo, I don't think it would turn out very well. So! I've been looking for beds online and came up with a few, First is Pro's Pick, any of you used or worked with this product? second, we all know Mid Fifty...Then Vintage ford in Sac. Would you guys suggest a package deal, front sides, brace frames etc? I guess i'd need to do it all new to keep it smooth and clean. Any helpful hints would be great!
Old May 9, 2006 | 01:43 PM
fatfenders56's Avatar
fatfenders56
I am using an original bed but this issue has been discussed a lot and for the money the Pros-Pick seems to be the ticket, I'm sure someone will be along shortly to give an opinion on that
Old May 9, 2006 | 01:49 PM
Okiedokie's Avatar
Okiedokie
I used Mar-K out of Okla City and am well pleased. Joe
Old May 9, 2006 | 02:23 PM
B/B ford's Avatar
B/B ford
Clean & Classy
If money is not the main concern, I would go for Pros-Pick complete package. I have their hidden hinge crossmember and tailgate and I am pleased with the quality. I bought my bed from mid-fifty but I think it is a mark- k product. I,m also very happy with it.
Old May 9, 2006 | 02:38 PM
low54's Avatar
low54
yeah, money is always an issue but I do like the smooth lines of the pros pick. Mid fifty isn't that much cheaper though...Its the shipping that really gets ya! Also, did you guys do much welding when you replaced you bed?
Old May 9, 2006 | 05:35 PM
fatfenders56
Mine has 2 spools of .030 wire in it!!!!!
Old May 9, 2006 | 06:37 PM
B/B ford's Avatar
B/B ford
Clean & Classy
I bolted mine together with p.s. button heads and acorn nuts(I,m no welder) I think it looks great!
Old May 10, 2006 | 07:36 AM
GreatNorthWoods's Avatar
GreatNorthWoods
I went with a ProsPick and have received the bed but haven't installed it yet. I bought mine at a show where ProsPick was a vendor. Although there is a $75 crating fee, if you can buy it at a show they will deliver it free. Check with them and find out which shows they are attending. My bed has no welding to be done...
Vern
Old May 10, 2006 | 10:32 AM
51ford fan's Avatar
51ford fan
Ditto on my 51 you can see pictures in my gallery. They even gave my free shipping, but if I wasn't in a big hurry I would have investigated purchasing the material and having the 45 bent in it and used a piece of pipe to make the circle part. I have seen a bed on a COE a guy had done that way and it was much stronger that the one I have. I also would have installed a steel bed floor, but that's just hind sight.
Rod 51F1
Old May 10, 2006 | 11:19 AM
low54's Avatar
low54
I'm no welder either...But may get a buddie to help me out. With the bed off i was thinking of putting in an ajustable 4-link suspension. or mono with rear sway bar. the pors pick seems to be the best route so far!
Old May 10, 2006 | 12:28 PM
51ford fan's Avatar
51ford fan
I'm also beginning to look at them, thet look like the solution if you don't plan to use the truck as a truck.
Old May 10, 2006 | 12:53 PM
jeff5683's Avatar
jeff5683
If you have the money, buy one.. The money spent on a new one is worth it concidering all of the frustration you would have with trying to fix the current one and screwing up, wasting money, starting over, etc.
Thats where I'm at right now.. I don't have the $$ for a new bed.. they don't make them for F-250's anyway.. trying to fix the one I've got and it was completely hacked to death because it was a wrecker, they cut off the back 1.5' of the truck!
This weekend I about freaked out and broke something I was so aggrivated lol..
Old May 10, 2006 | 03:33 PM
Jag Red 54's Avatar
Jag Red 54
I just went and bought a new one from Sac Vintage Ford. My body guy was going to charge me a bundle to get the old one in shape. It also came with the weld-in tear drops for the ends. I bolted it together and was very happy with the fitness. Good luck, Jag
Old May 10, 2006 | 05:15 PM
low54's Avatar
low54
Jeff5683-
Too bad your in Fl. I've got a 250 bed here in the North West...Its just sitting here waiting for the right person
Old May 10, 2006 | 05:21 PM
46achers's Avatar
46achers
I bought re-po crossmembers and had a bed farbriicated in a local shop for my 47.
I repaired the bed on my 46....never again.
Dave
